[Geoserver-devel] Pull request adding support for time relative expressions in WMS-T
After second reading I support Jody and the ecql syntax.
Andrea wrote:
“P standard for period, so that would not work. I guess it may may sense to use R (relative?), and get something
like R-2H/PRESENT. ”
Why would P not work because “period” and “duration” seem to be synonyms as they are used in Time/Time, Duration/Time, and Time/Duration syntax in http://docs.geoserver.org/latest/en/user/filter/ecql_reference.html#ecql-period ?
-Jukka-
Lähettäjä: Jody Garnett [mailto:jody.garnett@…403…]
Lähetetty: 3. joulukuuta 2014 10:17
Vastaanottaja: Andrea Aime
Kopio: Geoserver-devel
Aihe: Re: [Geoserver-devel] Pull request adding support for time relative expressions in WMS-T
That is cool, those ideas were only for another point of reference.
If we do not match ECQL exactly then it is probably not worth it. Could we skip the “prefix” and just use:
private final static String CONTINUOUS_RELATIVE_PERIOD_H = “2H/PRESENT”;
private final static String CONTINUOUS_RELATIVE_PERIOD_D = “10D/PRESENT”;
I guess I do not understand what “BACK” is needed for? I liked the ECQL technique of using “DURATION/TIME” or “TIME/DURATION”.
“BACK2H/PRESENT” is a belt and suspenders, I already know you are going to go back since the duration is before the time. It is not like you are going to say “FORWARD2H/PRESENT” (instead you would say “PRESENT/2H”).
Jody
Jody Garnett
On Wed, Dec 3, 2014 at 12:12 AM, Andrea Aime <andrea.aime@…1268…> wrote:
On Wed, Dec 3, 2014 at 8:43 AM, Jody Garnett <jody.garnett@…403…> wrote:
So this is for WMS-T … as in WMS Temporal.
The syntax is clear.
Here are two ideas for quick consideration:
CQL Time Duration
WFS 2.0 has temporal functions which we have dragged into CQL, any advantage to being consistent with the syntax here: http://docs.geoserver.org/latest/en/user/filter/ecql_reference.html#ecql-period
In particular the representation of time period seems nice and terse:
private final static String CONTINUOUS_RELATIVE_PERIOD_H = “P2H/PRESENT”;
private final static String CONTINUOUS_RELATIVE_PERIOD_D = “P10D/PRESENT”;
(There was no duration specified in weeks, I also did not see a representation for PRESENT, NOW … or FIRST or LATEST)
like R-2H/PRESENT.
WFS 2.0 FeatureId madness
This is probably a terrible idea, but you may wish to steal language such as FIRST and LATEST above.
The second thing WFS 2.0 has going on is the ability to query FeatureId based on previous, first or by date (see http://docs.geotools.org/latest/userguide/library/opengis/filter.html#identifer).
Any advantage to stealing the language of FIRST, PREVIOUS, etc…?
private final static String CONTINUOUS_RELATIVE_PERIOD_Y = “FIRST/P1Y”;
Hmm… I would not go there, WMS-T often works on a moving window, so FIRST and LATEST change daily or more often,
you never know what they mean.
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks to everyone for the feedback.
I liked Jody's suggestion of adding support for relative data by using FIRST
/ LASTEST keywords, but I can see that really understanding the context
would be difficult.
I've been using both WMS/WCS TIME and WFS ECQL for some time and would
prefer to use the ECQL temporal filter approach in WMS TIME. I'm not sure
if that is really possible though because of the support for animation in
WMS. My understanding is that period ("P" keyword in this case) in WMS does
not mean the same thing as in WFS - it is rather a 3rd temporal interval for
chunking the data window specified in the first 2 values for animating.
Unless people don't care about breaking this support it seems like another
means of specifying relative time is required.
I chose to use "BACK" as the keyword indicating relative time as it would
not cause confusion with other existing temporal keywords, while being brief
but clear. Using "R" would be more flexible and I like that suggestion.
This would allow going forward or backward in time relative to the present.
I can't see going forward in time very often though - unless your data is
prescient. This would allow you to potentially eliminate the "PRESENT"
keyword as you could just specify R0 or R0H.
One other reason it seems there needs to be a specific way to specify truly
relative times, apart from a Duration relative to a set Time, is if you want
to specify windowed data set back from the present. Take the example of
wanting to see a week of data set back 1 week from the present. Based on
the above discussion this would be specified as below:
TIME=R-2W/R-1W
As far as I can tell, this would not be available even in the present ECQL
syntax.
Thanks again for all the feedback. Based on whatever the consensus is I can
update my pull request.
Jonathan
Jonathan Meyer
Senior Software Engineer
Applied Information Sciences
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pull-request-adding-support-for-time-relative-expressions-in-WMS-T-tp5175938p5176231.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
I think you are the implementor so you get to choose :slight_smile: My mission was to stick more ideas in front of you and encourage consistency if possible.
I liked Jody’s suggestion of adding support for relative data by using FIRST
would be difficult.
I’ve been using both WMS/WCS TIME and WFS ECQL for some time and would
prefer to use the ECQL temporal filter approach in WMS TIME. I’m not sure
WMS. My understanding is that period (“P” keyword in this case) in WMS does
Unless people don’t care about breaking this support it seems like another
I chose to use “BACK” as the keyword indicating relative time as it would
but clear. Using “R” would be more flexible and I like that suggestion.
I can’t see going forward in time very often though - unless your data is
prescient. This would allow you to potentially eliminate the “PRESENT”
TIME=R-2W/R-1W
syntax.
Jonathan
Jonathan Meyer
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Jody Garnett
Just wanted to update the list that I had made changes to this pull request to add some user documentation as requested. The usage as also been changed to make it more consistent with the ECQL temporal predicates used in WFS requests. You can see the usage examples added to the documentation at the following link:
https://github.com/gisjon/geoserver/blob/8f638c540695255d8569d758c98e7461e674d10c/doc/en/user/source/services/wms/time.rst#specifying-a-relative-interval
Andrea said he wanted to wait a little bit to see if Simone Giannecchini had any feedback as he was the primary implementor of time support and then he’d merge.
Jonathan
On Wed, Dec 3, 2014 at 4:56 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
would be difficult.
TIME=R-2W/R-1W
syntax.
Jonathan
Jonathan Meyer
Hi guys,
Simone asked me to take a look to the pull request, the specs and what else to unlock the situation.
I have added my comments to the pull request and my final feedback is "OK to merge".
Here below a couple of additional comments:
The current “current” key usage is a bit weird in GeoServer (see my comments in the pull) and it also has a specific meaning in the WMS 1.3.0 Specification so that I agree with the “present” key alternative.
After the freeze, we can consider revisiting the “current” parsing/usage in GeoServer but this is unrelated with the work made by Jonathan.
Daniele
Dive into the World of Parallel Programming! The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net
Ing. Daniele Romagnoli
Jonathan
Jody Garnett
would be difficult.
TIME=R-2W/R-1W
syntax.
Jonathan
Jonathan Meyer
