I submitted the following pull request to geoserver master:
https://github.com/geoserver/geoserver/pull/318
Since the actual user is the geonode project, I would need this to be backported to 2.3.x which is the branch geonode works against. (and hence 2.4.x for the sake of completeness).
Please review and comment on any concern with it. (btw, I found it hard to come up with a unit test using the current testing infrastructure so if that’s needed and you have a recommendation on how to do so I’m all ears).
TIA,
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
On Wed, Sep 4, 2013 at 7:56 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Can we backport to 2.4.x once 2.4.0 is out?
that's needed and you have a recommendation on how to do so I'm all ears).
Eh, not easy indeed. The way to go would be, probably, to write a testing
store that acts like a mock, but whose
factory can be registered and be picked up by GeoServer as a real store.
Lot of work...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, Sep 4, 2013 at 3:08 PM, Andrea Aime <andrea.aime@anonymised.com>wrote:
On Wed, Sep 4, 2013 at 7:56 PM, Gabriel Roldan <groldan@anonymised.com>wrote:
Sure. The real question is whether we can backport to 2.3.x now. If not its
not a big issue, I guess they can run a custom build for the time being.
Lot of work...
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldan
On Wed, Sep 4, 2013 at 8:14 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
its not a big issue, I guess they can run a custom build for the time
being.
Hum... 2.3.x is officially abandoned, there are no more releases from it,
so I don't see a reason not to backport.
Unless others have objects and/or want to make more releases, but the patch
seemed innocuous enough
Ing. Andrea Aime
@geowolf
Technical Lead
