[Geoserver-devel] QA branch merged and checks integrated in the build
I’ve merged the QA branch. This means you’ll get build failures when there are PMD or ErrorProne violations.
On Travis, the QA checks look like a third build, e.g.:
This has been done in order to avoid making builds slower, as we have the 50 minutes limit.
On the build server, the checks have been directly integrated in the JDK11 build instead, while the JDK8 build
has been sped up to the max (e.g., no formatting checks, done in the JDK11 one)
in order to get quicker turnaround for test failures and downstream project tests.
There are no GeoServer specific docs but you can refer to the GeoTools ones,
they contain references to the tools web sites, how to run the locally, and how to annotate the code in order to get a particular
check ignored, to handle false positives:
https://github.com/geotools/geotools/blob/master/docs/developer/conventions/code/qa.rst
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
