[Geoserver-devel] QueryUsers community module dependency
Hi David,
I'm sending this to you as it seems you're the maintainer for the QueryUsers
community module.
The thing is when using the community profile, the web module depends on
QueryUsers, yet QueryUsers is not added to the community modules as per the
community module project pom.xml.
Should I just add it to the pom so it gets built when using the community
profile or there's something else about it?
cheers,
Gabriel
Oops, my mistake. I was using the QueryUsers module to verify that my
refactoring in RESTConfig had actually made the org.geoserver.rest module
reusable and must have accidentally committed the pom.xml file. If you'll
run an "svn up web/pom.xml" only the RESTConfig module should be included.
Thanks for pointing this out.
-David
On Tue, February 19, 2008 7:50 pm, Gabriel Roldán wrote:
Hi David,
QueryUsers
community module.
the community module project pom.xml.
cheers,
Gabriel
!DSPAM:4040,47bb795e296021137850744!
Cool, thanks for the prompt reply Dave.
Gabriel.
-David
> Hi David,
> QueryUsers
> community module.
> cheers,
> Gabriel
!DSPAM:4045,47bba20520674901796417!
