[Geoserver-devel] Question on GeoServer Security APIs and help understaing how filters work
Dear dev, dear Christian,
I’m struggling trying to create a prototype of an OAuth2 GeoServer Security Provider and Filter and would like to ask you some questions in order to better understand how the Security APIs work.
The Problem:
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Hi Alessio
I think a look at the CAS module would help. CAS also handles callbacks from the CAS Server
question 1)
The CAS filter handles handles all different requests (from clients and the CAS server). If this is not possible a would try to create a composite filter.
question 2)
The CAS module registers a special endpoint for incoming CAS Server reqeusts during geoserver startup.
Hope this helps.
Christian
On Wed, Aug 3, 2016 at 10:32 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
The Problem:
The OAuth2 protocol needs several steps to fully perform the authentication process.
Once we have created a “client_id” and “client_secret” on the OAuth2 Provider, in order to authenticate we need to:
  1. Obtain a valid “code” from the provider
  2. Use the “code” in order to get the final “access_token” which is used by the filter to get the Principal
Now, the issue is the following: The order in which these filters execute is very important.
we need two filters like this
<sec:custom-filter ref=“oauth2ClientContextFilter” after=“EXCEPTION_TRANSLATION_FILTER”/>
<sec:custom-filter ref=“oAuth2AuthenticationProcessingFilter” before=“FILTER_SECURITY_INTERCEPTOR”/>
  • oauth2ClientContextFilter must be invoked before oAuth2AuthenticationProcessingFilter, that’s because when a redirect to the OAuth2 Provider is required, oAuth2AuthenticationProcessingFilter throws a UserRedirectException which the oauth2ClientContextFilter handles and generates a redirect request to the Provider.
  • Subsequently the response from the OAuth2 Provider is handled by the oAuth2AuthenticationProcessingFilter to populate the Authentication object and stored in the SecurityContext
My Question Are:
  1. Which is the best approach to let the EXCEPTION_TRANSLATION_FILTER being intercepted before the FILTER_SECURITY_INTERCEPTOR? Is it sufficient to let our GeoServerOAuth2SecurityProvider make use of a custom ExceptionTransactionFilterProvider? Or maybe we need to create a custom composite Filter somehow?
  2. How can I create a GeoServer end-point to intercept the response of the redirect from the OAuth2 Provider allowing the oAuth2AuthenticationProcessingFilter handling the request? I tried to modify programmatically the filter-chain and (more-or-less) it seems working, but then GeoServer keeps saying that the dispatcher cannot handle the endpoint.
Any help/feedbak/hint is much appreciated and would be very very helpful.
Best Regards,
Alessio Fabiani.
@alfa7691
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
