Hi guys,
sorry for cross-posting.
I’m not sure if I have already asked that in the past (probably, but it was a couple of years ago but I didn’t find anything in my email history).
How the Osgeo artifacts mirroring works?
Long story short:
I had to manually add an artifact to geosolutions repository several days ago.
http://maven.geo-solutions.it/me/steinborn/libdeflate-java-core/0.1.0-beta/
A GT PR is failing due to a
java.lang.NoClassDefFoundError initialization error.
I suspect that it’s due to the artifact not being mirrored on Osgeo yet so the relevant class not being found.I cannot see it indeed in the index of artifacts.
https://repo.osgeo.org/#browse/browse:release
Is anyone familiar with the mirroring logic?
Is there any manual intervention that we can do to copy that artifact into Osgeo maven repository?
Please, let me know.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
