[Geoserver-devel] Question on PostGIS and views
That fixed it. Thanks!
-----Original Message-----
From: geoserver-devel-bounces@lists.sourceforge.net
[mailto:geoserver-devel-bounces@lists.sourceforge.net] On Behalf Of Randy
George
Sent: Wednesday, October 04, 2006 2:18 PM
To: Sadowski, Daniel
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Question on PostGIS and views
  It sounds like the geometry entry is missing. Did you make an entry
for the new view?
INSERT INTO "geometry_columns" VALUES
('','public','test','geom',2,4326,'MULTIPOLYGON');
More details here:
http://docs.codehaus.org/display/GEOSDOC/PostGIS+DataStore
randy
Sadowski, Daniel
Sent: Wednesday, October 04, 2006 3:07 PM
To: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Question on PostGIS and views
Hello,
I'm fairly new to Geoserver and GIS in general. I've managed to get
Postgress/PostGIS installed and my shape files moved into the database. I
configured the server to read the geometry from the tables and can display
overlays of the shapefiles that are read directly from the tables. However,
when I try to merge the shape data with some agricultural data via a view I
am having issues.
I can see the view that I have created in the Feature Type Name drop down
list, however, when I go to generate a bounding box from the view, I get the
following error:
The FeatureType 'varieties' has a NULL extent.
HINT: the dataset is empty or has no default geometry attribute.
It does not appear as if the geometry column is being returned correctly
from
the database.
Any advice would be really appreciated.
Dan
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
