[Geoserver-devel] questions about DataAccessEditPage
Fixing I bug I started looking at DataAccessEditPage and notice that it relies a lot on MapModel to manage form/object interaction. This seems like a lot of unnecessary work:
1) all properties have to marshalled from object to map
2) each property needs it's own well known key
3) all properties then have to be unmarshalled from the map back to object
Why not a CompoundPropertyModel? Or even using a regular PropertyModel would be more concise.
If I am missing something obvious in the approach, I apologize. Just looking at that page it struck me as a different from the other pages I have seen.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
I was just surprised as you when I first seen the page.
Given the amount of work I did not care to recode the page to
follow the normal structure.
Andrea Aime
Fair enough, I am not suggesting that we do, but I think for the future we should come up with a general convention of how to implement pages which basically follow the same paradigm: have a catalog/config object, need a form to change some of its properties, need to save that object after the fact.
Justin Deoliveira
it was about my first page and didn't use CompoundPropertyModel for a reason: ignorance :slight_smile:
Even if this is sort of an special case due to not being editing a closed set of fields I've been having this bad smell myself during these last weeks I've been working on the UI. So, if you open a jira issue for me I'll be glad of refactoring it to follow convention more close.
Gabriel
Gabriel Roldan
