So it looks like I missed a few things the last time I updated the user
installation files. Sorry about that.
I downloaded 0.95 distro of geoserver and could not find a war file
referred to in the user install instructions.
I created a geoserver.war file using ant after looking at the build.xml
for the right tag.
Sorry about not answering that question, it was emailed to the geoserver
list a little while ago, and I thought I had replied to list, but I only
replied to the sender. The answer to the question of 'where is the war?'
Is that it must be created by running 'ant war'. And if you update your
misc/data/featureType directory at all then the command must be run again.
I deployed this to my servlet container -jboss and it deployed
"successful" but there
was one error message that worried me:
some /tmp/.... file that it could not find/access (I will get the exact
path if you want).
Yes, please get me the exact path. It may be a jboss problem, as we have
not tested at all with jboss. If I have some time today I'll try to
download jboss and see if I get the same problem. Tomcat is by far the
most tested servlet container, and we have also successfully tested resin,
though not as extensively.
In the user install instructions it says to put a configuration.xml file
in "your web root" directory
then "geoserve/data".
Well, I am not sure if I know what is meant here. There is a
webapps/ROOT directory in
the /usr/local/geoserver/server directory where I have installed
geoserver. Is this what is meant?
First, I'll tell you what you should do, second I'll tell you what is
meant. The thing to do is just edit the configuration.xml file in
$GEOSERVER_HOME/misc/documents/. When you do 'ant war' this configuration
file will roll into the war, and will put itself in the right place when
placed in the servlet container. What is meant by 'your web root
directory' is the place where you expand the war. In the case of tomcat
it is $CATALINA_HOME/webapps, and I'm pretty sure it's called webapps in
resin too. So you place the geoserver.war in the appropriate place, and
then start up the servlet container, and it will expand to a /geoserver
directory, that will have a /data subdirectory, which is where the
configuration.xml file that you edited in geoserver/misc/documents ends
up. Which is to say that if you would like to edit the configuration
without having to rebuild the war each time then you can just edit that
file directly. You can do the same for the featureTypes in the data
directory. I personally do not recommend it, as I find it better to keep
my geoserver install consistent with the one expanded in the war, in case
you need to rebuild later, so you don't lose any changes you may have made
before.
There is no data directory under it - it is empty.
That directory will actually be expanded if you run 'ant test', which runs
the built-in tomcat, placing all the files in the correct places.
There is a data directory under geoserver/misc. Is this what are meant
by the data dir under web root?
Same as before, you can edit the data in geoserver/misc/data/featureTypes,
and have the changes go into the war. Or you can go to where the war has
expanded, your webapps directory, and edit them there.
Please also note the install instructions are out of date for postgresql:
it now uses gmake not make.
Thanks, I'll change it.
Further, a minor but I think important point:
The instrcutions for installing postgis say:
"You should place PostGIS in your Postgresql 'contrib' directory and
follow the directions for installation there."
There would be less mistakes if it said:
"You should place PostGIS in your Postgresql 'contrib', change to the
postgresql directory and follow the directions for installation there."
I tried running mak and make install from the 'contrib' directory and
got some confusing results
Sounds good, thanks for the catch.
I'll try to put these updates into the documentation soon, thanks for
emailing to clarify, and I apologize that it is confusing. And let me
know about the /tmp error, and I'll see what I can do as soon as possible.
good luck,
Chris
