[Geoserver-devel] questions about JaiMemoryCapacity
I ran into an issue when recently running wms cite tests. It seems that in some configurations JaiMemoryCapacity is a double, and a percentage of available memory, example "0.5". But in other configurations it seems it is a long, and an absolute value, example "209715200".
My question is which one wins? If you look at GeoServerDTO.Defaults.JaiMemoryCapacity it would point to long but GeoServerDTO.getJaiMemoryCapacity() it points to double.
After talking to Andrea on IRC it seems the double is the way to go. But I am confused why i have not run into this issue before... since I have run wms cite tests many times with the new configuration stuff on 1.7.
Anyone have an idea of what may be causing this?
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
in general the Jai Memory Capacity is a long representing the amount
of memory to be set ... in the geoserver specific case, at a certain
point the configuration value was changed ad a percentage of the total
amount of the available run-time memory.
Simone did this change, as soon as he will connect again will provide
more details on this.
        Alessio.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 349 8227000
On Fri, Dec 5, 2008 at 4:48 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Justin Deoliveira
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-devel mailing list
ehm , actually andrea did it :slight_smile:
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, Dec 5, 2008 at 5:25 PM, Alessio Fabiani
<alessio.fabiani@anonymised.com> wrote:
Hi Justin,
       Alessio.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
-Justin
Justin Deoliveira
Ok.. so it sounds like the double / percentage value is the way to go. I have proceeded accordingly.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Justin,
       Alessio.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
-Justin
Justin Deoliveira
Justin Deoliveira
Yep,
I think that it is much better than using an absolute value, since if
the value of the tileache capacity goes beyond or even to close to the
available runtime memory we could easily get into troubles.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Sat, Dec 6, 2008 at 5:30 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Hi Justin,
      Alessio.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
-Justin
Justin Deoliveira
Nevada.
help
Nevada.
Nevada.
Justin Deoliveira
