[Geoserver-devel] Random Access Error in Geoserver
Hello,
I am getting the following error or a variation of it when ingesting tif
files via Geotiff raster store.
"RandomAccessFile ERROR: Could not list layers for this store, an error
occurred retrieving them"
Upon re-starting Tomcat the error goes away and after some time it
re-appears.
Any help will be greatly appreciated.
Thanks.
Sri Vinay
CIESIN, Columbia University
On Sat, May 7, 2011 at 2:19 AM, Sri Vinay <sri@anonymised.com> wrote:
Hello,
re-appears.
Does not ring a bell (to me at least), can you enable geotools
developer logging,
reproduce the issue and send over the logs?
Also, how do you get this? Is it configuring data via the web admin interface,
via rest?
Is the same file that caused issues configured properly after restart?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Thanks for the prompt reply.
Current geotools developer setting:
log4j.category.org.geotools.factory=TRACE
log4j.category.org.geotools.renderer=DEBUG
log4j.category.org.geotools.data=TRACE
log4j.category.org.geotools.feature=TRACE
log4j.category.org.geotools.filter=TRACE
Should I change all of them to DEBUG?
Using web admin interface to configure.
Yes, the same file that caused the issue works fine after tomcat restart.
Sri
-----Original Message-----
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of
Andrea Aime
Sent: Saturday, May 07, 2011 2:13 AM
To: sri@anonymised.com
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Random Access Error in Geoserver
Hello,
re-appears.
developer logging,
interface,
via rest?
Ing. Andrea Aime
Tech lead
Just select the "geotools developer logging" profile from the user interface
Ing. Andrea Aime
Tech lead
Hi Andrea,
Enabled the "geotools developer logging" profile yesterday.
Hit the error again today.
Attached are two relevant logs:
1) log-with-error.txt - log when error happened.
2) log-without-error.txt - log when ingest went through without problem
after restarting tomcat.
We are running 2.1-RC5.
Please let me know if you need more info.
In the mean time, I am thinking of running a previous verion or nightly
build to see if that elimates the problem. Any suggestions?
Thanks.
---Sri
Of Andrea Aime
Sent: Saturday, May 07, 2011 12:54 PM
To: Sri Vinay
interface
Ing. Andrea Aime
Tech lead
(attachments)
log-with-error.txt (18.4 KB)
log-without-error.txt (19.3 KB)
Hi Andrea,
Sorry to hear you were injured and wishes for a speedy recovery.
Any help from the group on troubleshooting the issue (see email below) from
the group will be appreciated.
Please let me know if more information is needed.
Thanks.
---Sri
Sent: Monday, May 09, 2011 1:03 PM
To: 'Andrea Aime'
Cc: 'geoserver-devel@lists.sourceforge.net'
Subject: RE: [Geoserver-devel] Random Access Error in Geoserver
Hi Andrea,
build
Thanks.
---Sri
Behalf
> Of Andrea Aime
> To: Sri Vinay
> interface
> Cheers
> Andrea
> Ing. Andrea Aime
> GeoSolutions S.A.S.
> Tech lead
> Italy
(attachments)
Hi Sri,
which tomcat version are you using?
Is it > 6.0.24?
In that case I would suggest to try the fix recommended in 1.
Basically, what I can see from the log is that the geotiff reader asked ImageIO for an ImageInputStreamSpi instance on top of a File and it got an InputStreamImageInputStreamSpi.
However, that spi only deals with InputStream object whilst the source is a File → therefore the exception.
The ideal case would be to get a FileImageInputStreamSpi (being the source a File) and then create a FileImageInputStream stream.
This probably won’t happen because you are encountering the issue reported in that blog post.
Please, let me know if that’s your case.
Best Regards,
Daniele
On Wed, May 11, 2011 at 4:57 PM, Sri Vinay <sri@anonymised.com> wrote:
Hi Andrea,
Thanks.
—Sri
To: ‘Andrea Aime’
Cc: ‘geoserver-devel@lists.sourceforge.net
Hi Andrea,
Enabled the “geotools developer logging” profile yesterday.
  1. log-with-error.txt - log when error happened.
  2. log-without-error.txt - log when ingest went through without problem
build
Thanks.
—Sri
From: andrea.aime@anonymised.com… [mailto:andrea.aime@anonymised.com…] On
Behalf
Of Andrea Aime
To: Sri Vinay
Just select the “geotools developer logging” profile from the user
interface
Ing. Andrea Aime
Tech lead
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
Geoserver-devel mailing list
Ing. Daniele Romagnoli
Software Engineer
http://it.linkedin.com/in/danieleromagnoli
Hi Daniele,
The tomcat version is 6.0.16. Should I still try the solution suggested in the blog?
Thanks for your prompt reply.
—Sri
From: dany.geotools@anonymised.com03… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Wednesday, May 11, 2011 12:10 PM
To: sri@anonymised.com0…
Cc: Andrea Aime; geoserver-devel@lists.sourceforge.net
Hi Sri,
Is it > 6.0.24?
Best Regards,
Daniele
Hi Andrea,
Thanks.
—Sri
To: ‘Andrea Aime’
Hi Andrea,
build
Thanks.
—Sri
Behalf
Of Andrea Aime
To: Sri Vinay
interface
Ing. Andrea Aime
Tech lead
Software Engineer
Hi Sri,
On Wed, May 11, 2011 at 7:05 PM, Sri Vinay <sri@anonymised.com50…> wrote:
Hi Daniele,
You could try, since as far I can see from the log, the geotiffreader isn’t getting the proper SPI (It seems like it isn’t properly registered).
Let me know if that fixes your issue.
Daniele
—Sri
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Hi Sri,
Is it > 6.0.24?
Best Regards,
Daniele
Hi Andrea,
Thanks.
—Sri
To: ‘Andrea Aime’
Hi Andrea,
build
Thanks.
—Sri
Behalf
Of Andrea Aime
To: Sri Vinay
interface
Ing. Andrea Aime
Tech lead
Software Engineer
Software Engineer
Hi Daniele and Andrea,
Upgrading Geoserver to version 2.1.0 seems to have fixed this problem as well.
Thanks.
—Sri
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com.] On Behalf Of Daniele Romagnoli
Sent: Wednesday, May 11, 2011 1:09 PM
Hi Sri,
On Wed, May 11, 2011 at 7:05 PM, Sri Vinay <sri@anonymised.com0…> wrote:
Hi Daniele,
Daniele
—Sri
Hi Sri,
Is it > 6.0.24?
Best Regards,
Daniele
Hi Andrea,
Thanks.
—Sri
To: ‘Andrea Aime’
Cc: ‘geoserver-devel@anonymised.comt
Hi Andrea,
build
Thanks.
—Sri
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com.403…] On
Behalf
Of Andrea Aime
To: Sri Vinay
interface
Ing. Andrea Aime
Tech lead
Software Engineer
Software Engineer
