[Geoserver-devel] Raster attribute table support... core or plugin?
I’d like to discuss placement of the Raster Attribute Table support in the GeoServer codebase.
A Raster Attribute Table (RAT) is a set of metadata found in .aux.xml files that can sidecar a raster file, which contains one or more possible classifications of the raster data. So, it’s roughly the equivalent of one or more raster symbolizer ColorMap.
But first, what’s a RAT? The XML representation looks as follows:
https://github.com/noaa-ocs-hydrography/qgis-raster-attribute-table-plugin/blob/master/tests/data/2x2_1_BAND_FLOAT.tif.aux.xml
QGIS has a plugin, the raster attribute plugin, that can be used to deal with the RAT, the file above becomes:
There we have 3 possible classifications, called class, class2, class3. The result of using “class” and then pressing the classify button is:
The QGIS style has been overridden with one from the RAT, picking classes, colors and labels.
So the idea for GeoServer is to have something similar, a panel in the GUI that would recognize the presence of a RAT in the source raster, and would create on demand (press of a button)
create a SLD, and associate it with the current layer.
So question… what do you think in terms of placement? Core panel, that shows up in case the source data has the RAT, or community module, which would do the same?
PS: please let’s not start with a “we could have a concept of native style”, yes, it’s a good idea, it would just require a whole other level of effort. If someone manages to get enough resources to add the necessary core changes and UI for it, migrating the RAT support will be pretty easy.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Oh, in case you’re wondering “why are you even asking?” it’s because as a plugin the panel would
end up in a random position in the tab, while if I could place it into core, there would be an opportunity
to place it right below the style chooser (so one generates styles, and can see the result right away
in the associated style list)
(attachments)
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Question: is there more than one RAT for a coverage? Or does a single RAT always just define multiple classifications? I ask because your example just has one RGB mapping …
Add a hook to layer publishing tab to add a generate style button - which would generate a style (in this case from a RAT class). Community module to implement against the hook. Workflow is nice, when publishing you can use the button to generate some styles (in the workspace styles directory which are immediately listed for use).
Other ideas:
  1. Can these RAT classifications show up as a additional coverages to be published - so the rest of the codebase is unchanged? So the coveragestore would list “layer” (raw values) and “layer-class”(processed by the RAT), “layer-class2”, “layer-class3” - the RAT in effect defines additional coverages. Minimal change, no style generation.
  2. if you wanted to view and edit the RAT - define a new UI much like we have for SQL view allowing RAT to be defined, accessible from the layer data tab.
Jody
(attachments)
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
I would love to fix the random position in the tab problem :slight_smile: even just sorting would be better than what we have now …
(attachments)
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Well it can be addressed at least partially with implementation of ExtensionPriority, but would require touching all panels.
In any case, a worthy goal if you have time, for sure
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
It’s weird, but the way it goes, is that you can have multiple classifications, but … they all share the same break values and the same colors: all that changes between one classification
and the other are the labels. Here is a more complex example, for vegetation types, according to different nomenclatures:
Other ideas:
They are just styles, data is the same, it’s not a different coverage, it’s different colors and labels in a ColorMap.
There is no need to change the codebase, adding styles and associating them is currently how styling works.
  1. if you wanted to view and edit the RAT - define a new UI much like we have for SQL view allowing RAT to be defined, accessible from the layer data tab.
No intention of editing the RAT.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
