On Thu, Feb 4, 2016 at 3:44 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Since this falls between GeoTools and GeoServer, I figured I'd bump it and
cross-post.
Phrased differently, "Does the CoverageFactory interface have the same
hooks for auto EditPanel generation as the DataStore interface?"
As the minute, in order to add a raster data source, we are finding that
we have to override GeoServer classes. For vector data sources, we have
never had to do that. Are we missing something?
You probably are? A GUI is automatically generated for rasters too.
Contrary to what Jody suggest, there are no parameters in a raster source,
the Format class just accepts
a "Object source" without any description of what it could be, the list of
"read parameters" is to be used
once the GridCoverageReader is already acquired, from the interface:
* Retrieve the parameter information for a {@link
GridCoverageReader#read read} operation.
@UML(identifier="getParameterInfo, numParameters",
obligation=MANDATORY, specification=OGC_01004)
ParameterValueGroup getReadParameters();
The default DefaultCoverageStoreEditPanel assumes this object is a URL. If
your source requires something
else then yes, you have to build your own panel
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
