The GCRenderer will (or at least should :-)) handle it.
Be aware that the performance could be bad, try to at least do some
decimation on loading.
Simone.
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
-----Original Message-----
From: Farber, Saul (EEA) [mailto:Saul.Farber@anonymised.com]
Sent: venerdì 3 agosto 2007 18.43
To: Simone Gannecchini; Farber, Saul (EEA); Andrea Aime
Cc: geoserver-devel@lists.sourceforge.net
Subject: RE: [Geoserver-devel] Raster reprojection
Simone,
Great explanation. That makes much sense.
The flow you explain below (the first one...the 'real world' one, rather
than the 'perfect world one')...does that exist today? If my XXXgcReader
plugin returns a mis-sized, untranslated coverage, will GCRenderer reproject
it for me?
I'm fairly sure that it will...I just wanted to double check!
--saul
From: Simone Gannecchini [mailto:simboss1@anonymised.com]
Sent: Fri 8/3/2007 12:19 PM
To: 'Farber, Saul (EEA)'; 'Andrea Aime'
As I said what happens depend on how much the single plugin is implementing.
A plugin could do everything by itself comprehending the reprojection but I
usually do not do that.
Daniele and I are working on a couple of GDAL-based plugins for various
formats (MRSID, JP2 and ECW) which should be a bit more advanced with
respect to the others we have but still we don't do any reprojection.
The way I envision a good plug-in should work is like a best effort
approach, but in the end what I think would be a nice behaviour is the
following:
0) Coverage native EPSG is XXXX.
1) Request for coverage in 4326 comes in.
2) Request for coverage in 4326 is passed to XXXgcReader
3) XXXgcReader reproject the request back to XXXX crs
4) XXXgcReader load only the needed area(crop) at the best resolution
available(decimation or overviews)
5) XXXgcReader build a coverage in crs XXXX with data from 4)
6) GridCoverageRenderer reprojects whatever was returned from XXXgcReader
(which is in EPSG:9999) into EPSG:4326 by doing cropping, resampling,
etc...essentially "reprojection"
7) The reprojected raster is returned to the caller
In a perfect world a plugin should work as follows:
6) XXXgcReader scale the coverage from 5)at the resolution requested and
to fit the view extent requested (in pixels)
7) XXXgcReader reproject coverage in crs 436 with data from 6)
8) GridCoverageRenderer reprojects simply apply the grid-to-world transform
to place the coverage at the right place on the final graphics.
9) The reprojected raster is returned to the caller
As everybody knows we don't live in a perfect world, doing all steps from 0
to 9 could add to complexity to the single plugins, but it would be feasible
moving some functionality up in the grdicoverage hierarchy. Actually if
someone has money to spend on this I would be glad to work on it :-).
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
http://www.geo-solutions.it/>
Sent: venerdì 3 agosto 2007 17.24
To: Andrea Aime; Simone Gannecchini
Yeah, what andrea asked is what I'm curious about.
So I think this is what happens:
0) Coverage native EPSG is 9999.
3) XXXgcReader does whatever it can to try and return some relevant data,
but returns it in EPSG:9999
4) GridCoverageRenderer reprojects whatever was returned from XXXgcReader
5) The reprojected raster is returned to the caller
Is that right? I'm only fuzzy about step 4...should I be doing step 4
INSIDE the XXXgcReader, or will the GridCoverageRenderer handle it on its
own?
thanks so much Simone,
--saul
From: geoserver-devel-bounces@lists.sourceforge.net on behalf of Andrea Aime
Sent: Fri 8/3/2007 11:06 AM
Cc: geoserver-devel@lists.sourceforge.net; 'Farber, Saul (EEA)'
Subject: Re: [Geoserver-devel] Raster reprojection
Simone Gannecchini ha scritto:
Ciao Saul,
I am not sure I am included in the raster "gurus" dataset but since no
one
else is answering I will try a best effort approach to serve your query.
(Yeah, I am tired and I need a vacation :-().
The behaviour I tried to implement in most readers was the following. If
someone is making a request to get part or all of a coverage I pass this
request to the coverage reader untouched then it is up to the reader to
ignore it or to make use of it.
What I usually do is reprojecting the envelope back to the coverage native
CRS and then intersect it with the original envelope in order to decide
whether or not the request will be satisfied.
A whole set of optimizations (that should be improved sometime in the
future) can be used, overviews management, decimation on reading,
cropping,
etc. All of the require the reprojection of the requested envelope into
the
native coverage crs.
Whatever, but most readers do not reproject the data themselves, the
renderer is doing it, no? So, what do you do, you just reproject
the envelope to the native crs of the coverage to perfom the actual
data extraction, and then return the coverage in the native crs?
Geoserver-devel mailing list
