[Geoserver-devel] Raster Support [was] Re: [Geoserver-users] Newbie
John Preston wrote:
> I have a number of raster maps (.png's) that I wish to serve up with > geoserver using a openlayers client. It is not clear from the geoserver > web site whether geoserver supports doing this. I installed the most > recent stable version but I can't find any possibility to serve up > raster (geocoded image) files, only shape files. Can someone tell me > which is the current best way to do this with opensource software. There's a branch that has support for such things: http://docs.codehaus.org/display/GEOSDEV/WCS+Branch But it hasn't had a release in awhile, and thus would be tough for a newbie to get up and running.
I do have some experience with programming Java so if the WCS+Branch is functional and allows tiling I would try that first. I would prefer a Java solution because I wish to experiment with some on-the-fly manipulation of source data and Java gives me the best possibility for this. I had tried sometime ago to get the WCS code to work but I was having erros associated with the HSQLDB database. Can you point me to somewhere where I can get info on getting the WCS-Branch to work.
John
Sure. You'll have to check it out from SVN and build it, as our WCS branch guys are over-worked merging to trunk on geotools. See: http://docs.codehaus.org/display/GEOSDEV/WCS+Branch
The svn command to do is 'svn co svn://svn.codehaus.org/geoserver/branches/wcs-branch/trunk/geoserver'
Then you'll have to build it, and you should be able to select your files from the web admin tool. I think 'WorldImage' is the right one. For better performance there's also an experimental imagemosaic datastore, but Alessio or Simone would have to tell you moreR
!DSPAM:1003,44995dc720861362196140!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
