[Geoserver-devel] RasterSymbolizer
Hi there. I'm working on a document detailing new support for RasterSymbolizer in 1.7.0. I'm going off of the official OGC spec, but I'm curious how much of the spec has been implemented. Specifically:
* <Opacity> (I've verified this works)
* <ColorMap> (tested for single channel sources only)
* <ChannelSelection>
* <ContrastEnhancement> (incl Normalize, Histogram, and GammaValue)
* <ShadedRelief>
* <OverlapBehavior>
* <ImageOutline> (incl Line and Polygon Symbolizer)
I've tried making guess on how to develop SLD based on the OGC spec [1] and the Geotools page [2], but I figure I'd ask here before I assume that my problems are user error!
[1] http://www.opengeospatial.org/standards/sld
[2] http://geotools.codehaus.org/Raster+Symbolizer+support
Mike Pumphrey
OpenGeo - http://opengeo.org
Ciao Mike,
glad to see that you playing with the RasterSymbolizer.
I will give you a quick answer but I would also like to ask you if you
could ping me back when you have something that I could add to since
there ar e a few extension to the SLD spec that I would like to document.
Anyway, see below..
implemented
It does work for single channel sources or you have to select a single
source yourself. It is not legal to apply a ColorMap to a multiband
raster without selecting a band. I ave added a few extensions to this
element.
implemented
implemented with some extensions as well
* <ShadedRelief>
NOT implemented
* <OverlapBehavior>
NOT implemented
NOT implemented (it would be trivial)
Simone.
Mike Pumphrey
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-devel mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
