Ciao Andrea,
situation is as follows:
-we are internally working on trunk (gt and gs) for new plugins
-gdal should be aligned between 2.5 and 2.6
-mosaic is not algined since on trunk there are some old modifications
done specifically for udig which I would need to incorporate (ore
probably kill) somehow.
The plan is to align mosaic in the next weeks and probably check again
imageio-ext support, since daniele started to work on gdal 1.6.1
support.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Tue, Aug 4, 2009 at 10:58 AM, Andrea Aime<aaime@anonymised.com> wrote:
we're about to release RC1. Yet, I think, trunk is still quite far
behind the 1.7.x series when it comes to coverage management?
I may be wrong, but I think there are significant changes in the
mosaic module, and maybe in the gdal ones, that haven't been
ported over to gt2 trunk and thus are not available for GeoServer
trunk, making it less functional than the 1.7.x series
Is this correct? (if not, apologies, must have missed the
relevant commits). If it is, what are the plans to port over
the code to (gt2) trunk?
Andrea Aime
OpenGeo - http://opengeo.org
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
