* Java 1.4 and JAI
+ this is the configuration that i run; it works fine for me - I've
never had any troubles.
* Java 1.4 without JAI
+ I also tested this configuration.
for GIF:
org.vfny.geoserver.wms.responses.map.gif.Gif89Encoder.simpleColorReducer(Gif89Encoder.java:245)
This is because the image has more than 256 colours in it (probably from
anti-aliasing). I recently changed ("removed") the colour reduction
algorithm because the old one had problems. You should report this as
a bug.
dave
This mail sent through IMP: https://webmail.limegroup.com/
