[Geoserver-devel] RC3 Viewer paths appear wrong + SLD configuration
Dave, I tried what you suggested below but all the paths in the generated context docs point to localhost - this needs to change to the full hostname. After doing that, it works, but not brilliantly.
-the image dimensions don’t match the layer proportions so the map is squashed.
-the legend graphic is not fetched
otherwise, at least you can test that the WMS and SLD are working.
SLD configuration problem / bug (RC3):
I created a new style which loaded an SLD into geoserver. I Applied but did not Save. Then I had to restart Geoserver for another reason. As expected, the style was not in the configuration, but when I tried to add it again, Geoserver complained that there was already an SLD by that name, so I had to manually delete the .sld file from geoserver.
Either a newly loaded .sld file should only be saved when the user Saves, or Geoserver should allow the user to overwrite an existing sld through the web app. Or am I missing something?
thanks
gavin
dblasby@anonymised.com 05/10/2005 21:46 >>>
Gavin,
This will be fixed in the next version.
Here’s something you can try (I’m not sure if it will work):
  1. visit the new page - mapPreview.do (the generated/ directory should
    be populated)
  2. copy the generated/ directory to either the WAR file or the exploded
    WAR file (“server/geoserver/data/”)
This will allow the generated files to be available via http.
dave
This mail sent through IMP: https://webmail.limegroup.com/
This SF.Net email is sponsored by:
Power Architecture Resource Center: Free content, downloads, discussions,
and more. http://solutions.newsforge.com/ibmarch.tmpl
Geoserver-devel mailing list
This message is subject to the CSIR’s copyright, terms and conditions and e-mail legal notice.
Views expressed herein do not necessarily represent the views of the CSIR.
CSIR E-mail Legal Notice
CSIR Copyright, Terms and Conditions
For electronic copies of the CSIR Copyright, Terms and Conditions and the CSIR Legal Notice
send a blank message with “REQUEST LEGAL” in the subject line to CSIR HelpDesk
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
