forwarding to geoserver devel list since it could be of interest to others.
---------- Forwarded Message ----------
Subject: Re: ArcSDE permission
Date: Monday 12 September 2005 18:20
To: Lena Pahl <Lena.Pahl@anonymised.com>
Hi Lena,
no problem in contacting me directly.
I'm a bit stretched today, but I promise giving you an answer tomorrow.
Sorry for the inconvenience, and please stay connected since I need more
ArcSDE testers like you
cheers,
Gabriel.
P.S. I did got your previouse message, just forgot to answer! I'm so sorry.
On Monday 12 September 2005 13:58, Lena Pahl wrote:
Hi Gabriel!
Sorry for posting directly to your email adress. Did you get my last email?
I enclose it again for you. Do you have any ideas what the problem might
be? Or do you have any hints what else I could try? I would like to use
WFSDataStore to connect to ArcSDE. How do you make sure to have permission
to do transactions? Muchas gracias for your help and time!
Lena-----------
Concerning the WFSDataStore: I always get the "NO PERMISSION TO PERFORM
OPERATION" error, nomatter if I leave out "map.put(WFSDataStoreFactory.USERNAME,"user");
map.put(WFSDataStoreFactory.PASSWORD,"pwd");" or not.
I'm using ArcSDE 8.2 and Oracle8. The Geotools version is 2.1 and GeoServer
1.2.4 Inserts and Modifying do not work. When I try to insert I get this
output/error:07.09.2005 09:56:44 org.geotools.data.arcsde.ConnectionConfig checkParams
WARNUNG: No database name specified
07.09.2005 09:56:45
org.geotools.data.arcsde.ArcSDEConnectionPool$SeConfigReportreportConfiguration
WARNUNG: ***
ArcSDE configuration info:
*** ArcSDE Server info: ****Server name: chekov
ArcSDE version: 8.2.0 - Oracle8i Build 1057 Wed Mar 6 09:48:05 PST 2002
Accepting connections: true
Blocking connections: false
---- Instance configuration: ----
Instance is read-only: false
Home path: C:\arcgis\ArcSDE\ora8iexe
Log path: UNUSED
Max. connections: 64
Max. layers: 500
Max. streams: 25 (maximum number of streams allowed by the ArcSde instance)
Stream pool size: 3 (maximum number of streams allowed in a native pool.)
07.09.2005 09:56:49 org.geotools.data.arcsde.ArcSDEAdapter parseCRS
INFO: About to parse CRS for layer FLURSTUECKE_1:PROJCS["Germany_Zone_3",GEOGCS["GCS_Deutsche_Hauptdreiecksnetz",DATUM["D_De
utsche_Hauptdreiecksnetz",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich"
,0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_E
asting",3500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",9.0],PARAMETE
R["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
INFO: Se CRS envelope:
(3535987.952702,5800565.866202,3544577.88729,5809155.80079) 07.09.2005
09:56:50 org.geotools.data.arcsde.ArcSDEAdapter parseCRS INFO: About to
07.09.2005 09:56:50 org.geotools.data.arcsde.ArcSDEAdapter parseCRS
09:56:50 org.geotools.data.arcsde.ArcSDEFeatureWriter write WARNUNG:
com.esri.sde.sdk.client.SeException:
at com.esri.sde.sdk.client.j.a(Unknown Source)
at com.esri.sde.sdk.client.SeInsert.intoTable(Unknown Source)
at
org.geotools.data.arcsde.ArcSDEFeatureWriter.write(ArcSDEFeatureWriter.java:267) at
org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.jav
a:224) at ArcSDETest1.main(ArcSDETest1.java:88)
org.geotools.data.DataSourceException:
at
org.geotools.data.arcsde.ArcSDEFeatureWriter.write(ArcSDEFeatureWriter.java:312) at
Caused by: com.esri.sde.sdk.client.SeException:
at
org.geotools.data.arcsde.ArcSDEFeatureWriter.write(ArcSDEFeatureWriter.java:267) ... 2 more
Kind regards,
Lena-----------
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
