[Geoserver-devel] Re: AW: AW: [Geoserver-users] Transaction by LockID
What version of GeoServer are you using? This should really have been
caught by cite testing, which David ran right before putting out
1.3-beta2. Give that version a try. And yeah, if you can send him or
me a server location that we can hit, we should be able to try it out.
Chris
Quoting Eugen Gass <gass@anonymised.com>:
I'm sure that the LockId is right. I take the LockId from Response
and use
it
for my update requests. It's realy the same LockId. I have no idea
why it
doesn't work???
I lock always as postgres admin user to my database and it's no a
rights
problem.
best regards
Eugen
Von: Chris Holmes [mailto:cholmes@anonymised.com]
Gesendet: Dienstag, 12. April 2005 16:29
An: Eugen Gass
Betreff: Re: AW: [Geoserver-users] Transaction by LockID
That error makes a lot more sense. It does beg the question of are
you
sure you're using the proper lockId? You lock features, and get back
a
certain lockId, and that's the one you're using on the update? I'd
be
surprised if that doesn't work, as it's pretty well tested on the
cite
tests. Be sure that you cut and paste exactly.
Chris
> Hi,
> after Isend you the first Log file I set the example database
called
> "dcmms"
> to false.
> After restart I made a new update with LockId and I got another
> service
> exception like:
> 777728 [FEINER] GMLFilterDocument - RETURN
> 777728 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.242 13
> 777728 [FEIN]
> org.vfny.geoserver.requests.wfs.TransactionFeatureHandler -
> we ar
> e inside attribute: false, curAttType is null curFeatureT: null
> attName
> 777728 [FEINER] org.geotools.filter.ExpressionSAXParser - incoming
> message:
> top
> p:objectid
> 777728 [FEINER] org.geotools.filter.ExpressionSAXParser - should
> read
> chars: tr
> ue
> 777728 [FEINER] org.geotools.filter.ExpressionSAXParser - ...
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - setting
> attribute
> exp
> ression: objectid
> 777738 [FEINER] ExpressionAttribute - ENTRY objectid
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - ...
> 777738 [FEINER] GMLFilterDocument - RETURN
> 777738 [FEINER] GMLFilterDocument - ENTRY
http://www.opengis.net/ogc
> PropertyNa
> me ogc:PropertyName
> 777738 [FEINER] org.geotools.filter.FilterFilter - found start
> element:
> Propert
> yName
> 777738 [FEINER] AbstractFilter - ENTRY 101
> 777738 [FEINER] org.geotools.filter.FilterFilter - found an
> expression
> filter e
> nd
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - declared
> type:
> Proper
> tyName
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - end
> message:
> Property
> Name
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - current
> state:
> comple
> te
> 777738 [FEINER] org.geotools.filter.FilterFilter - expression
> factory is
> ready
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - about to
> create
> expre
> ssion: objectid
> 777738 [FEINER] org.geotools.filter.FilterSAXParser - current
state
> (end):
> righ
> tValue
> 777738 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.275 1
> 777738 [FEIN]
> we ar
> attName
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - incoming
> message:
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - should
> read
> chars: fa
> lse
> Literal og
> c:Literal org.xml.sax.helpers.AttributesImpl@anonymised.com
> element:
> Literal
> 777738 [FEINER] AbstractFilter - ENTRY 109
> type:
> Litera
> l
> type:
> Proper
> tyName
> state:
> comple
> te
> 777738 [FEINER] org.geotools.filter.ExpressionSAXParser - is
literal
> expression
> 777738 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.289 4
> 777738 [FEIN]
> we ar
> attName
> message:
> 683
> 4
> read
> chars: tr
> ue
> Literal og
> c:Literal
> element:
> Literal
> expression
> filter e
> nd
> type:
> Litera
> l
> message:
> Literal
> state:
> comple
> te
> factory is
> ready
> create
> expre
> ssion: 6834
state
> (end):
> comp
> lete
> 777738 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.308 1
> 777748 [FEIN]
> we ar
> attName
> 777748 [FEINER] org.geotools.filter.ExpressionSAXParser - incoming
> message:
> 777748 [FEINER] org.geotools.filter.ExpressionSAXParser - should
> read
> chars: fa
> lse
> 777748 [FEINER] GMLFilterDocument - RETURN
> 777748 [FEINER] GMLFilterDocument - ENTRY
> PropertyIs
> EqualTo ogc:PropertyIsEqualTo
> 777748 [FEINER] org.geotools.filter.FilterFilter - found start
> element:
> Propert
> yIsEqualTo
> 777748 [FEINER] AbstractFilter - ENTRY 14
> 777748 [FEINER] org.geotools.filter.FilterSAXParser - complete
> called,
> state =
> complete
> 777748 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.334 1
> 777748 [FEIN]
> we ar
> attName
> message:
> read
> chars: fa
> lse
> Filter
> ogc
> :Filter
> element:
> Filter
> 777748 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.349 1
> 777748 [FEIN]
> we ar
> attName
http://www.opengis.net/wfs
> Update
> wfs
> :Update
> element:
> Update
> 777748 [FEINER] org.vfny.geoserver.requests.wfs.TransactionHandler
> at end
> ele
> ment: Update
> 777748 [FEINER] GMLFilterDocument - ENTRY [C@anonymised.com 1.364 1
> 777748 [FEIN]
> we ar
> attName
> Transactio
> n wfs:Transaction
> element:
> Transac
> tion
> at end
> ele
> ment: Transaction
> 777748 [FEINER]
> org.vfny.geoserver.requests.readers.wfs.TransactionXmlReader -
> just parsed: org.xml.sax.InputSource@anonymised.com
> 777758 [INFO] org.vfny.geoserver.servlets.AbstractService -
handling
> request: L
> ock Id: GeoServer_48331fb556fc6609
> releaseAction: ALL
> handle: null
> TypeName: topp:linie_frei
> handle: null topp:linie_frei 1
> ReleaseAll: true
> filter: [ objectid = 6834 ]
> Property - Name: objectid, Value: 6834
> Property - Name: objektbesc, Value: 6834
> Property - Name: elementgru, Value: wfs test2
> Property - Name: kartenid, Value: 314
> Property - Name: darstellun, Value: 0
> Property - Name: strichstae, Value: 1
> Property - Name: farbe, Value: 1
> Property - Name: fk_objekta, Value: 0
> Property - Name: lookupfiel, Value: 000101
> Property - Name: shape_len, Value: 94857742
> 777758 [FEIN] org.vfny.geoserver.servlets.AbstractService -
strategy
> is:
> org.vf
> ny.geoserver.servlets.FileStrategy@anonymised.com
> 777758 [FEINER] org.vfny.geoserver.servlets.AbstractService -
> executing
> request
> 777758 [FEIN] org.vfny.geoserver.responses.wfs.TransactionResponse
> request is
> Lock Id: GeoServer_48331fb556fc6609
> releaseAction: ALL
> handle: null
> ReleaseAll: true
> Locating F
> eatureSource 'topp:linie_frei'...
> 777758 [FEIN] org.vfny.geoserver.global.Data - getting type
> topp:linie_frei
> located Fe
> atureType w/ typeRef 'Postgis:linie_frei' and elementName
> 'topp:linie_frei'
> 777758 [FEIN] org.geotools.data.postgis.PostgisDataStore - get
> Feature
> source c
> alled on linie_frei
returning
> pg
> feature
> locking
> 777758 [FEINER]
> - got
> lock
> 777758 [FEINER] org.vfny.geoserver.global.DataStoreInfo - in
string
> url
string
> url
> 777758 [FEIN] org.vfny.geoserver.ServiceException - Attempting to
> use a
> lockID
> that does not exist, it has either expired or was entered wrong.
> 777758 [WARNUNG] org.vfny.geoserver.servlets.AbstractService -
> service
> exceptio
> n while executing request: Lock Id: GeoServer_48331fb556fc6609
> releaseAction: ALL
> handle: null
> ReleaseAll: true
> cause: Attempting to use a lockID that does not exist, it has
either
> expired
> or
> was entered wrong.
string
> url
string
> url
> 777758 [WARNUNG] org.vfny.geoserver.ServiceException - encountered
> error:
> Attem
> pting to use a lockID that does not exist, it has either expired or
> was
> entered
> wrong.
> StackTrace: org.vfny.geoserver.WfsException: Attempting to use a
> lockID that
> doe
> at
org.vfny.geoserver.responses.wfs.TransactionResponse.execute(Transact
> ionResponse.java:271)
> at
> ionResponse.java:104)
> at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService
> .java:362)
> at
org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.ja
> va:300)
> at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doResponse(WfsDispatche
> r.java:245)
> at
org.vfny.geoserver.servlets.wfs.WfsDispatcher.doPost(WfsDispatcher.ja
> va:134)
> at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
> at
> javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
> at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358
> at
org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicati
> onHandler.java:294)
> at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:5
> 67)
> at
org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
> at
org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplication
> Context.java:525)
> at
org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
> at org.mortbay.http.HttpServer.service(HttpServer.java:879)
> at
> org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
> at
> org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
> at
> org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
> at
org.mortbay.http.SocketListener.handleConnection(SocketListener.java:
> 197)
> at
> org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
> at
> org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
> 777758 [FEIN] org.vfny.geoserver.ServiceException - return wfs
> exception is
> <?x
> ml version="1.0" ?>
> <ServiceExceptionReport
> version="1.2.0"
> xmlns="http://www.opengis.net/ogc&quot;
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://localhost:8080/geoserve
> r/data/capabilities//wfs/1.0.0/OGC-exception.xsd">
> <ServiceException>
> org.vfny.geoserver.WfsException: Attempting to use a lockID
> that does
> not
> at
> at
> at
> .java:362)
> at
> va:300)
> at
> r.java:245)
> at
> va:134)
> at
> at
> at
> at
> onHandler.java:294)
> at
> 67)
> at
> at
> Context.java:525)
> at
> at
> at
> at
> at
> 197)
> at
> at
> </ServiceException>
> </ServiceExceptionReport>
> I hope it helps.
> best regards
> Eugen
This mail sent through IMP: https://webmail.limegroup.com/
