[Geoserver-devel] Re: build.xml test-ext broken?
You either need a conf directory (default) or need to include a variable on the command line.
optionally you can un-comment one of these in the file.
  <!--<property name="test.type" value="CitePostGis"/>-->
  <!--<property name="test.type" value="CiteShapeFiles"/>-->
David
jgarnett@anonymised.com wrote:
I grabed the latest greatest from cvs and was unable to get the "test-ext"
target to build. So either the head is broken, or I missed to new instructions
you no doubt sent to the list?
Of course all this means is that I have not been destracted by that testing
thing I keep hearing so much about.
Jody
Thanks for the instructions David, they did fix my problem. But we still have an issue to address - the conf directory on HEAD appears to be Chris Holmes's personal directory, and it appears to be incomplete.
Chris: what are you plans for the conf directory on HEAD?
I could for see a couple of good things here...in order of preference.
a) leaving conf off of HEAD so each developer can make there own conf directory for their environment, with an easy starting place being to unzip one of the pre-canned conf directories. This would involve us setting conf to be ignore by CVS, so that the developers own work would not be overwritten.
b) using the developers conf directory (shapefile based) as the conf directory on HEAD, this would allow developers to checkout the latest CVS and work against the documentation examples.
c) using the user's conf directory (shapefile based, maybe an external example to public TOPP postgis instance?), this would allow developers to always work against, what our end user's will see.
My goals for this is:
- have the a well known conf structure used as common example for the developer documentation
  (yes I know we have that as an ant build option)
- provide a well known conf structure used as common example for user documentation
  (yes I know we have that as an ant build, and ant generated distribution)
- allow developers to have their own environment with little fuss and bother
  (options b & c would get in the way of this, but it may be worth the effort to keep user's conf well tested)
feedback?
Jody
David
Jody
I've been thinking about this stuff as well, as I have been annoyed at the
default conf stuff of late as well. I got David to do the initial change,
as I wanted to be able to use my conf directory. David, I just modified
the build.xml again, basically rolling your options up to war instead of
just in test-ext, so to build the war you can choose to have a zip file or
your conf directory. I like option c) the best, as I don't like not
having a conf there at all, since it is harder for developers to build up
their conf directory from scratch than to just modify one existing. I'm
not sure I understand the difference between b) and c), as I don't know
what developers documentation examples you're talking about. In my mind
the easiest thing would be to make the developers docs use the user conf
directory stuff. I don't see much of a reason for a developer to work
with the cite test types, as I find them to be sort of bad examples, as
they are all small and aren't real at all. They're great for testing
cite, but not much else, so I don't see any reason to have developers work
against them. If developers want the conf directory to be ignored then
can't they just put in their own .cvsignore or something? We can make
docs that talk about this. I'd like to keep the user's conf well tested,
I don't like just having some zipped up directory that we put in the
releases without completely testing it. In the past I've always had the
conf directory be the one that developers and users both get, and I see no
reason to change that. The release build should always be done from a
freshly checked out cvs directory structure, to ensure that nothing is out
of sync at all, so I personally don't see a need for a zipped standard
UserConf directory structure. It was actually never really my personal
conf/ directory, that came with the admin tool merge; I've always made it
an example file, with good comments, the datastores were just sample
params for all available datastores, so that developers could modify them
as they wanted to. So those were my plans. Do they work with you guys?
Is it ok if we add the conf directory back in? I'm fine with a few more
sample featureTypes if that's what's needed for a well known conf
structure to be the example in the developer docs.
Chris
On Wed, 18 Feb 2004,
not be overwritten.
documentation
feedback?
Jody
> David
>> "test-ext"
>> instructions
>> testing
>> Jody
SF.Net is sponsored by: Speed Start Your Linux Apps Now.
Build and deploy apps & Web services for Linux with
a free DVD software kit from IBM. Click Now!
http://ads.osdn.com/?ad_id=1356&alloc_id=3438&op=click
Geoserver-devel mailing list
Hey chris, did not see you on irc today. I am reviewing documentation and trying to retire a few Jira tasks today.
I am afraid I have come a bit late to the conf directory, build.xml party - David build.xml file did let me switch between conf, and zipfiles based on command line parameters. (You mentioned fixing something that worked for me).
Chris Holmes wrote:
I've been thinking about this stuff as well, as I have been annoyed at the default conf stuff of late as well. I got David to do the initial change, as I wanted to be able to use my conf directory.
That is what I thought, my only concern is that you want to version control your conf directory on HEAD as well.
I like option c) the best, as I don't like not having a conf there at all, since it is harder for developers to build up their conf directory from scratch than to just modify one existing. I'm not sure I understand the difference between b) and c), as I don't know what developers documentation examples you're talking about.
This is that mythical documentation we have been talking about! The difference is that I would like *bad* examples as part of the developer conf directory: cite tests, invalid geometries for the validator to catch, and so on.
I did not want to annoy the user with this sort of thing, and I get the impression that you would also like to provide users with working "good" examples.
In my mind the easiest thing would be to make the developers docs use the user conf directory stuff. I don't see much of a reason for a developer to work with the cite test types, as I find them to be sort of bad examples, as they are all small and aren't real at all.
By developer I am refering to a GeoServer developer, making use of or extending the Framework. These are exactly the people I would like to be able to run the cite tests with little or know effort.
They're great for testing cite, but not much else, so I don't see any reason to have developers work against them.
See above - until we have more junit tests, I would like cite tests easily accessable. I remember back to December where I was stuck hacking on GeoServer with no way to tests, I don't want to put others in that situation.
If developers want the conf directory to be ignored then can't they just put in their own .cvsignore or something?
No .cvsignore is shared, and version controlled.
I'd like to keep the user's conf well tested, I don't like just having some zipped up directory that we put in the releases without completely testing it. In the past I've always had the conf directory be the one that developers and users both get, and I see no reason to change that.
It seems that cite shapefiles, and whatever invalid geometries I dream up for validation will be the major sticking points against having a shared conf directory.
It still think it would be easiest to have no conf in cvs, and have "conf" ignored by cvs, so all developers can unpack a conf directory and make use of it without having cvs clobber it every update. This would allow developers to work against the users conf, or the cite conf, or their own conf as needed.
What I don't think we should do is check in a conf on head that has ties to local databases at refractions or topp (which we have both done in the past).
The release build should always be done from a freshly checked out cvs directory structure, to ensure that nothing is out of sync at all, so I personally don't see a need for a zipped standard UserConf directory structure. It was actually never really my personal conf/ directory, that came with the admin tool merge; I've always made it an example file, with good comments, the datastores were just sample params for all available datastores, so that developers could modify them as they wanted to. So those were my plans.
Cool that is what we need to know - what your plans are.
So the open questions are:
- Should we use the same conf for both developers and users?
Pros: everybody tests together, Cons putting cite and other undesireable or even broken DataStores in the face of users.
What we need is:
- nail down the conf directory that ships with the user's war for documentation, screen snaps.
- nail down a conf directory for the developer documentation.
What I would like:
- conf not on head, so I put my own there and have test-ext suck it up
The only advantage to a ziped standard UserConf is consistency for documentation, and having a the application start up the first time they see it without any errors. I think the zip file is a bit much to maintain though, if it is broken out as a directory we can manage things a bit better using cvs.
Do they work with you guys? Is it ok if we add the conf directory back in? I'm fine with a few more sample featureTypes if that's what's needed for a well known conf structure to be the example in the developer docs.
