I think that there is a problem with the catalog.xml in the above download. There is a missing for the Tasmania_roads.
Add here and it will work.
Thanks for the catch Randy, this is an unintended side effect of getting rid of the warnings you pointed out. We'll get this in 1.3.1.
best regards,
Chris
Randy George wrote:
download. There is a missing </datastore> for the Tasmania_roads.<datastore namespace = "topp" enabled = "true" id = "tasmania_roads" >
<connectionParams>
<parameter value =
"file:data/featureTypes/tasmania_roads/tasmania_roads.shp" name = "url" /></connectionParams>
Add </datastore> here and it will work.
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
Hi Chris,
You might want to consider a 1.3.1 release fairly soon since the
existing war deployment will give a validation error and not allow the
geoserver interface to come up.
Here is the exception trace:
javax.servlet.ServletException: trouble parsing XML in
java.io.FileReader@anonymised.com: Content is not allowed in prolog.
org.vfny.geoserver.global.GeoServerPlugIn.init(GeoServerPlugIn.java:14)
org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServlet.java:
1158)
org.apache.struts.action.ActionServlet.init(ActionServlet.java:473)
javax.servlet.GenericServlet.init(GenericServlet.java:211)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:868)
org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processC
onnection(Http11BaseProtocol.java:663)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.jav
a:527)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWo
rkerThread.java:80)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.jav
a:684)
java.lang.Thread.run(Thread.java:595)
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Thursday, February 16, 2006 12:45 PM
To: Randy George
Cc: 'Geoserver-devel'
Subject: Re: [Geoserver-devel] RE: geoserver-1.3.0-war.zip
best regards,
Chris
Randy George wrote:
<connectionParams>
<parameter value =
</connectionParams>
Chris Holmes
Argh, I thought it was a more minor error, since I just tested this on the exe release. Thanks for prodding on this, we just put up a 1.3.0a-war.zip. This complements our other 1.3.0a releases, which went up because they had old docs. I thought the pre-release was supposed to iron out these problems, but for some reason it didn't...
The links from http://docs.codehaus.org/display/GEOS/GeoServer+1.3.0 should now all point to the 1.3.0a releases, except for the .exe one, which we're still waiting on Brent to build.
best regards,
Chris
Randy George wrote:
Hi Chris,
geoserver interface to come up.Here is the exception trace:
1158)
a:527)
rkerThread.java:80)
a:684)
java.lang.Thread.run(Thread.java:595)-----Original Message-----
Holmes
To: Randy George
Subject: Re: [Geoserver-devel] RE: geoserver-1.3.0-war.zipThanks for the catch Randy, this is an unintended side effect of getting rid of the warnings you pointed out. We'll get this in 1.3.1.
best regards,
Chris
Randy George wrote:
<connectionParams>
<parameter value =
"file:data/featureTypes/tasmania_roads/tasmania_roads.shp" name = "url"/>
</connectionParams>
Chris Holmes
