[Geoserver-devel] Re: Geoserver-devel digest, Vol 1 #410 - 1 msg
Hi Chris,
I have been trying out geoserver for the past few months, and I find it
very useful. I just love the direction this development is going, which
will allow me to ditch some very expensive software. I am very interested
in geoserver - oracle spatial connection, and I have an Oracle 9i R2 box
that I admin, so it should be very easy for me to test those latest changes
that you are talking about. Problem is I don't have the time right now to
dive into geoserver's code or download & compile, so if you could put up a
war that would make it very easy for me to test these changes from a pure
user's point of view.
Juan Marín Otero
TRAGSATEC S.A.
Departamento de Cartografía
Tlf. 91 322 64 98
| | geoserver-devel-request@anonymised.com|
| | ceforge.net |
| | Enviado por: |
| | geoserver-devel-admin@anonymised.com|
| | forge.net |
| | 29/07/2004 05:02 |
| | Por favor, responda a |
| | geoserver-devel |
  | Para: geoserver-devel@lists.sourceforge.net |
  | cc: |
  | Asunto: Geoserver-devel digest, Vol 1 #410 - 1 msg |
Send Geoserver-devel mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
             geoserver-devel-request@lists.sourceforge.net
You can reach the person managing the list at
             geoserver-devel-admin@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-devel digest..."
Today's Topics:
   1. Re: GeoServer with Oracle Spatial (cholmes@anonymised.com)
--__--__--
Message: 1
Date: Wed, 28 Jul 2004 10:48:05 -0400
To: bdt@anonymised.com
Cc: geoserver-devel@lists.sourceforge.net,
        geotools-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Re: GeoServer with Oracle Spatial
I'm busy putting on GeoServer on an Oracle Spatial DB. I've done some
bug
fixes I'm explaining in this mail. May be you can improve my roadmap
First question is which release of GeoServer should I rely on.
Optimistically I started with 1.2-rc2. As I had much problems I went
down
to 1.1.1.
Darn, I wish you had gotten in touch earlier, I just completed a bunch
of bug fixes to get oracle spatial working with geoserver on the 1.2
branch. I'm testing on 10g, and it would be great if you could test
out on an earlier version. You should definitely rely on 1.2, I can
put an rc3 out for you probably tomorrow (which if all goes well I'll
probably rename 1.2.0 pretty soon, as I need to get that out).
There is one thing the GeoServer team can do to facilitate such
operation.
It would be absolutly great to have a way to get the exact source
code of
the geotools library used for each release of GeoServer. I've had
much trouble trying several versions and I finally decided to
decompile the jars
you distribute. One way would be to redistribute the GeoTools source
code in your source bundle. Another way would be to provide the exact
versionnumber to use in the geotools CVS. This is important because
GeoTools seems to be moving on fast and the coupling between both
products is strong.
Yes, we've been working on this. The problem in the past has always
been that geotools doesn't really release, so it was hard to match up
exactly with it. In the old geotools cvs I put in a few geoserver
tags, so that one could check out the exact source, but I've gotten
lazy on the past few releases. The next releases of both are going to
actually be coordinated though. GeoServer 1.2.0 will use GeoTools
2.0-rc1 - I'm doing all my bug fixes on the 2.0.x branch of geotools,
which is quite nice because in the past we had to hand roll jars to
avoid unstable portions of geotools. Once we put out gs 1.2.0 we will
release gt 2.0-rc1 using the exact same code that geoserver uses. And
if you're interested in working off of cvs the geotools 2.0.x branch
(http://svn.geotools.org/geotools/branches/2.0.x/) is what the
geoserver cvs is using - I'm keeping the jars in geoserver inline with
those built from that branch.
As my comments have much impact on GeoTools, I copy them to the
GeoTools mailing list
Cool, I'm moving this to geotools-devel. Most of the core geotools
developers are on both lists, as we're tightly coupled projects, both
in code and the developers writing the code.
Let's go on !
Problem 1: There are 2 major releases of sdoapi that have sightly
different
interfaces
Ok, I think we may have already solved this problem, by skipping the use
of the sdoapi.jar completely. Jody Garnett at Refractions wrote an
sdoapi replacement, in anticipation of the fact that 10g was not going
to include the sdoapi. Since that has happened we've put his changes
in geotools and geoserver makes use of them. So for geoserver you just
need to include the classes12 jar, and oracle should work. It would be
great if you could test these out on earlier versions of oracle, since
I've only done 10g - but it was written before 10g was out, so should
work with earlier versions.
Here while everything compiles with the original source code and
while the
casting to OracleConnection is correct as you are connected to
Oracle, for
a reason I could not understand, the VM could not resolve the
getGeometryMetaData at runtime ?!? The previous version of sdoapi
required
an OracleConnection so it is correct in a way to do it as it used to
be. It
just did not work.
That is _very_ odd.
There is a more protable alternative for
determining the
srid by doing the following query:
"select srid from user_sdo_geom_metadata where table_name='"
+tableName.toUpperCase()+"' and column_name='"
+geometryColumnName.toUpperCase()+"'"
Yes - this is exactly what I did:
http://svn.geotools.org/geotools/branches/2.0.x/gt/plugin/oraclespatial/src/org/geotools/data/oracle/OracleDataStore.java
Ok, not exactly, I didn't do toUpperCase, which I suppose wouldn't be a
bad thing - though Jody is against such 'magic'. I actually think it
makes sense for oracle, as nothing works if things aren't upper case.
I'm sorry that we just had to replicate work, I probably should have
notified the list more of my fixes.
1c. I had another such problem in
org.geotools.data.oracle.OracleSDOAttributeReader constructor with
the call
to OraSpatialManager.getSpatialReferenceManager(conn); The new code
of this
functions stands here:
      public OracleSDOAttributeReader(AttributeType metaData,
QueryData
queryData,
int
columnIndex) throws DataSourceException
            super(new AttributeType
                        metaData
                  , queryData, columnIndex, columnIndex + 1);
            this.queryData = queryData;
            this.columnIndex = columnIndex;
            try
                  String tableName = queryData.getFeatureTypeInfo
().getFeatureTypeName();
                  String columnName = metaData.getName();
                  LOGGER.fine("About to create Geometry convertor for
tableName +
                                          columnName);
                  //BDT: Used to be OracleConnection
                  Connection conn = queryData.getConnection();
                  oracle.sdoapi.geom.GeometryFactory gFact = null;
                  int srid = queryData.getFeatureTypeInfo
().getSRID(columnName);
                  if (srid != -1)
                        SRManager srManager =
                              conn);
                        oracle.sdoapi.sref.SpatialReference sr =
srManager.retrieve(srid);
                        gFact =
OraSpatialManager.getGeometryFactory(sr);
                  else
                        gFact =
OraSpatialManager.getGeometryFactory();
                  adapterSDO = new AdapterSDO(gFact, conn);
                  adapterJTS = new AdapterJTS(gFact);
            catch (SQLException e)
                  queryData.close(e, this);
                  String msg = "Error setting up SDO Geometry
convertor";
                  LOGGER.log(Level.SEVERE, msg, e);
                  throw new DataSourceException(msg + ":" +
e.getMessage(),
e);
            catch (SRException e)
                        "Error setting up SDO Geometry convertor",
                        e);
If you could review this on the 2.0.x branch that would be great, I'm
not quite sure of the fix here.
Problem 2 : The BBOX constraint does not work because the name of the
geometric column is implicit. Fix in
org.geotools.filter.SQLEncoderOracle
In the constructor I take note of the first geometric column from the
srids
Map
      public SQLEncoderOracle(String fidColumn, Map srids)
            LOGGER.fine("SQLEncoderOracle("+fidColumn+","+srids+")");
            escapedWildcardMulti = "\\.\\*";
            escapedWildcardSingle = "\\.\\?";
            currentGeomColumnName = null;
            inGeomFilter = false;
            this.srids = srids;
            this.fidColumn = fidColumn;
      //BDT try and determine the geometric column name from the
provided
srids
            Set geomCols = srids.keySet();
            if (geomCols.size() > 0)
                  currentGeomColumnName = (String)
geomCols.iterator().next
            LOGGER.fine("SQLEncoderOracle: Geometric Column is:"
+currentGeomColumnName);
In doBBoxFilter I add a tolerence for left == null and in this case
use
currentGeomColumnName instead
      private void doBBoxFilter(GeometryFilter geomFilter) throws
IOException
            Expression left = geomFilter.getLeftGeometry();
            Expression right = geomFilter.getRightGeometry();
            if ((left != null || currentGeomColumnName != null) &&
right !
= null)
                  inGeomFilter = true;
                  out.write("SDO_GEOM.RELATE(");
                  if (left != null)
                        left.accept(this);
                  else
                        out.write(currentGeomColumnName);
                  out.write(",'ANYINTERACT',");
                  right.accept(this);
                  out.write(",0.001) = 'TRUE' ");
            else
                  LOGGER.warning(
                        "Invalid filter. Cannot have a Geometry
filter with
only one expression.");
This is the one fix I didn't get to yet - I noticed it but didn't do it.
You definitely have the right approach, it's what I do in postgis
datastore. I'll commit it soon, and hopefully you can test it out?
That would help me out a lot, since setting up my oracle testing
environment is a bitch.
thanks a lot for this work, it's all solid code, it's just unfortunate
that we were working on the same stuff at the same time. If you could
test out 2.0.x branch and geoserver 1.2 that would be great, and I can
get you an updated geoserver war if you'd like.
Chris
This mail sent through IMP: https://webmail.limegroup.com/
--__--__--
End of Geoserver-devel Digest
Este correo es sólo informativo y por lo tanto no supone obligación
contractual para TRAGSATEC ni para las sociedades a ella vinculadas. La
información incluida en el presente correo electrónico es CONFIDENCIAL,
siendo para el uso exclusivo del destinatario arriba mencionado. Si usted
lee este mensaje y no es el destinatario señalado, el empleado o el agente
responsable de entregar el mensaje al destinatario, o ha recibido esta
comunicación por error, le informamos que está totalmente prohibido
cualquier almacenamiento, divulgación, distribución o reproducción de esta
comunicación y de los archivos que pueda contener. Le rogamos que nos lo
notifique, devuelva el original al emisor del correo y destruya el mensaje.
El correo electrónico vía Internet no permite asegurar la confidencialidad
de los mensajes que se transmiten, ni su integridad o correcta recepción.
TRAGSATEC no asume responsabilidad por estas circunstancias. Si el
destinatario de este mensaje no consintiera la utilización del correo
electrónico vía Internet y la grabación de los mensajes, rogamos lo ponga
en nuestro conocimiento de forma inmediata.
Glad you're liking the software, feel free to give feedback on what
you'd like us to work on next.
I can definitely put a war up for you at any point. I think I'm going
to try to release rc3 today on sourceforge, and if I get some feedback
on it and it seems good I will probably just rename it 1.2.0, since I
need to get that out soon. It won't be in as good shape as I'd like,
but I won't be able to put a whole ton of work in in the next few
weeks, so I need to get it out. Hopefully I can fix the oracle bug
that I'm getting, though right now I just can't figure out what's wrong
with it. So yes, if I don't get rc3 out today I'll send you a link to
the war at the end of the day.
Chris
Quoting Juan Marín Otero <jmo@anonymised.com>:
Hi Chris,
it=
which=
interest=
ed
bo=
x
cha=
nges
now =
to
u=
p a
p=
ure
Juan Mar=EDn Otero
TRAGSATEC S.A.
Departamento de Cartograf=EDa
Tlf. 91 322 64 98
| | ceforge.net |
| | Enviado por: |
| | forge.net |
| | 29/07/2004 05:02 |
| | geoserver-devel |
  | cc:
https://lists.sourceforge.net/lists/listinfo/geoserver-dev=
el
Today's Topics:
--__--__--
Message: 1
> Hi,
some=
> bug
roadmap
went
> down
> to 1.1.1.
bunch
> operation.
> code of
> decompile the jars
source
exact=
> products is strong.
to
will
And
with
> Let's go on !
> different
> interfaces
us=
e
going
just=
be=
since
> while the
> Oracle, for
> required
to
> be. It
> just did not work.
That is _very_ odd.
> determining the
> "select srid from user_sdo_geom_metadata where table_name=3D'"
> +tableName.toUpperCase()+"' and column_name=3D'"
http://svn.geotools.org/geotools/branches/2.0.x/gt/plugin/oraclespatial=
a=
> the call
> of this
> QueryData
> queryData,
> int
> metaData
> this.queryData =3D queryData;
> this.columnIndex =3D columnIndex;
> try
> String tableName =3D queryData.getFeatureTypeInfo
> String columnName =3D metaData.getName();
for=
> tableName +
> columnName);
> Connection conn =3D queryData.getConnection();
> oracle.sdoapi.geom.GeometryFactory gFact =3D
null;
> int srid =3D queryData.getFeatureTypeInfo
> if (srid !=3D -1)
> SRManager srManager =3D
> conn);
> oracle.sdoapi.sref.SpatialReference sr =3D
> gFact =3D
> else
> gFact =3D
> adapterSDO =3D new AdapterSDO(gFact, conn);
> adapterJTS =3D new AdapterJTS(gFact);
> String msg =3D "Error setting up SDO Geometry
> convertor";
> e.getMessage(),
> e);
> e);
the=
the=
> srids
> Map
LOGGER.fine("SQLEncoderOracle("+fidColumn+","+srids+")");=
> escapedWildcardMulti =3D "\\.\\*";
> escapedWildcardSingle =3D "\\.\\?";
> currentGeomColumnName =3D null;
> inGeomFilter =3D false;
> this.srids =3D srids;
> this.fidColumn =3D fidColumn;
> provided
> srids
> Set geomCols =3D srids.keySet();
> currentGeomColumnName =3D (String)
> In doBBoxFilter I add a tolerence for left =3D=3D null and in this
ca=
se
> use
> IOException
> Expression left =3D geomFilter.getLeftGeometry();
> Expression right =3D geomFilter.getRightGeometry();
> if ((left !=3D null || currentGeomColumnName !=3D null)
> right !
> =3D null)
> inGeomFilter =3D true;
> if (left !=3D null)
> left.accept(this);
> else
> right.accept(this);
> out.write(",0.001) =3D 'TRUE' ");
> else
> LOGGER.warning(
> filter with
it=
unfortunate
could
can
Chris
--__--__--
Este correo es s=F3lo informativo y por lo tanto no supone
obligaci=F3n=
La=
informaci=F3n incluida en el presente correo electr=F3nico es
CONFIDENC=
IAL,
ust=
ed
lee este mensaje y no es el destinatario se=F1alado, el empleado o el
a=
gente
esta
comunicaci=F3n por error, le informamos que est=E1 totalmente
prohibido=
cualquier almacenamiento, divulgaci=F3n, distribuci=F3n o
reproducci=F3=
n de esta
comunicaci=F3n y de los archivos que pueda contener. Le rogamos que
nos=
lo
mens=
aje.
El correo electr=F3nico v=EDa Internet no permite asegurar la
confiden=
cialidad
recepc=
i=F3n.
Si=
  el
destinatario de este mensaje no consintiera la utilizaci=F3n
del =
correo
electr=F3nico v=EDa Internet y la grabaci=F3n de los mensajes,
rogamo=
s lo ponga
en nuestro conocimiento de forma inmediata.=
This SF.Net email is sponsored by BEA Weblogic Workshop
FREE Java Enterprise J2EE developer tools!
Get your free copy of BEA WebLogic Workshop 8.1 today.
http://ads.osdn.com/?ad_id=4721&alloc_id=10040&op=click
