Forwarding from users list, hoping somebody of the dev's happens to know if it should (or not) be possible to use a GeoPackage with a time-dimension in Geoserver.
For what I tested not ('Datetime' columns are always shown as 'String'), but I'm hoping somebody tells me here, I am wrong...
Richard Duivenvoorde
-------- Original Message --------
Subject: Re: [Geoserver-users] Geopackage (Vectors) as Time Dimension / WMS-T store. Experience?
Date: 2019-11-04 10:29
From: Richard Duivenvoorde <rdmailings@anonymised.com>
Reply-To: rdmailings@anonymised.com
Didn't
Next try: not attached but downloadable: https://duif.net/dt.zip
In the meantime I also created an issue:
https://osgeo-org.atlassian.net/browse/GEOS-9392
Follow up (well I hope this attachment makes it through spamfilters...).
Attached a minimal gpkg created with QGIS with a dt column being type
DATETIME. Both in QGIS and in sqlitebrowser the type of the column is
shown as DATETIME, attached also a screenie of sqlitebrowser.
But registring this gpkg in Geoserver, the dt column is determined as a
String column (also screenie attached).
Maybe I'll create an issue for this with same files attached.
On 04/11/2019 09.37, Richard Duivenvoorde wrote:
Nobody? Trying to use Geopackage with datetime columns?
I tried to edit a gpkg in QGIS with DB Manager to change the column to a
DATETIME. Which seemsOpening that gpkg in Sqlitebrowser revealed the columns as:
CREATE TABLE "foo"
("fid" INTEGER PRIMARY KEY AUTOINCREMENT NOT NULL,
"geom" MULTIPOLYGON,
"cell" REAL,
"value" REAL,
"datumtijd" DATETIME NOT NULL)But still GeoServer does not offer me a TimeDimension..
Anybody?
On 29/10/2019 20.44, Richard Duivenvoorde wrote:
I'm trying to get a Geopackage working in latest (2.16) Geoserver as
WMS-T (WMS with a Time Dimension).
The data has a geom table with a polygon-"grid" column, a dataset with
several time-based values per 'cell', AND a view which joins them together.
The 'Time'-column is a seconds since epoch column.I found that Sqlite does not have a real datetime format, but does have
several options to produce Datetime's based on text or integer columns [0].
But I failed to create a view which could be understand by Geoserver
that the column created was an actual 'datetime'
Anybody experience with this, or maybe have some more info?I also found that the geopackage spec defines a DATE and DATETIME type
[1] Requirement 5, but saves it as an sort of iso-string. Creating such
a column did not work either.
With Geoserver I had the same issue: geoserver did not recognize the
column as a DateTime.So I wonder: should I be able to use a Geopackage as a DataStore for a
layer, to serve as a WMS-T with a TIME dimension?
Did I miss something?
Maybe do some remapping of types?Any hints/tips would be appreciated.
Geoserver-users mailing listPlease make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.htmlIf you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
