[Geoserver-devel] Re: [Geoserver-users] win32 installer
I fixed this problem for the 1.3.0-beta2. I run from "C:\program
file\geoserver 1.3\" directory, so I know its working now.
By the admin tool, you mean the jetty admin tool "localhost:8081" or the
geoserver configuration tool ("localhost:8080")?
Both of these should be working in 1.3.0-beta (the older beta) - I
tested them here as well (the -beta2 has a better way of solving the
problem than the original beta).
Are you using a JDK/SDK? If you're just using a JRE you dont have a
compiler to compile the .jsps - you must have a JDK!
http://docs.codehaus.org/display/GEOS/How+to+Download+and+Install+Geoserver
dave
ps. -beta2 should be comming out tomorrow or monday.
This mail sent through IMP: https://webmail.limegroup.com/
Hi Dave,
I meant the geoserver configuration tool (localhost:8080).
I am using the latest 1.4 J2SDK (j2sdk-1_4_2_07).
Best regards,
Bart
dave
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
