[Geoserver-devel] Re: Geoserver
Hello David,
I imagine folks on the geoserver-devel list can help you out with some of your detailed questions. I am not sure if the latest release is available as WAR yet, I will check.
Paul
David Williams wrote:
Paul,
I have Geoserver Release 1.3.0-RC1 War File which I installed on TomCat.
I had to download the JAI for the "Range" Method and also, the Demo's don't work and there
are many URL's that are not valid.
The web page said that now in 1.3.1 there is no need for JAI Jar's and that's good but there
in no NEW War file on Sourceforge. I don't mind reporting some of the Bug's but is there
a more stable, prior release where the War file works?
Thank You
David
Basically the non-jai stuff didn't quite get finished, so it's still
more or less required. You can try the beta4 release, and you might
actually get some more stability. Though in both cases you'll need
JAI.
Chris
Quoting Paul Ramsey <pramsey@anonymised.com>:
Hello David,
some
Paul
> Paul,
TomCat.
Demo's
and
the
> Bug's but is there
> Thank You
> David
SF.Net email is sponsored by: Discover Easy Linux Migration
Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
