Hi Lena,
This is a good question, and the answer is you cant really, yet. However the work to be able to do this has been going on a geoserver branch. Check out http://docs.codehaus.org/display/GEOS/Experimental (Complex Data Store).
Merging this work into geotools / geoserver is going to be the priority of the geoserver 1.4.x stream of development.
-Justin
Lena Pahl wrote:
Yeah, you're right - it's not that large. I'll try to track down the problem. Though it seemed to me that the size of the geometry is an issue. Maybe it's in Geotools. I'll email as soon as I find out.
Can I ask another question? How do I union - let's say 2 features - using GeoServer? How does that work in Geotools? Thanks!
LenaJustin Deoliveira <jdeolive@anonymised.com> schrieb am 12.01.06 20:03:32:
Hi Lena,
170 coordinates isn't that large, shouldn't be a resource problem at all. Something else must be going wrong.
-Justin
Lena Pahl wrote:
Hi Justin!
I encoutered problems with a polygon of 170 coordinates. I didn't have any trouble dealing with a feature polygon of 70 nodes.Justin Deoliveira <jdeolive@anonymised.com> schrieb am 11.01.06 19:43:14:
I would think the only limit is memory, it could be that your polygon has so many coordinates that you are running out of memory. Do you have any idea of how many coordinates your polygon has?
Lena Pahl wrote:
Hello!
I don't know if my problem is related to GeoServer or Geotools so I'm posting this to both lists...
Is there a known limitation to the number of nodes/points that a multipolygon can have? I was wondering - because sometimes when I insert features with large geometries into ArcSDE using GeoServer those features cannot be deleted anymore. Querying works fine though..
Did anybody have that experience? How many points can a multipolygon/polygon have anyways? Any help is highly apreciated... Thanks!
Lena
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193-------------------------------------------------------
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users--
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org-------------------------------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-users______________________________________________________________
Justin Deoliveira
Geotools-gt2-users mailing list
Geotools-gt2-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users______________________________________________________________________
XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
Justin Deoliveira
