[Geoserver-devel] Re: getfeature bug
I discover the next possible bug in geoserver, in the getfeature function i
get the gml document from the
http://localhost:port/geoserver/GetFeature?FeatureName=road request
i declare the road Feature in the namespace topp. The request wuold be
http://localhost:port/geoserver/GetFeature?FeatureName=topp:road ?
Yeah, that's intentional. topp is the default namespace, so that if you
don't specify a namespace it defaults to that. This was for backwards
compatibility, as we used to not handle namespaces. But I think it's
still kind of nice to be able to not have to specify the annoying topp:
prefix before everything, if all your features are in the same namespace.
I did change the defaultNamespace to be the first defined one if the
'default' attribute was not used, as the 'default' attribute wasn't
necessarily intuitive if you only wanted to define one namespace. Users
were defining namespaces and wondering why myns was still showing up. The
request with the namespace of topp: still works right? If not then it's a
bug, and I'd like to see your configuration files to try to replicate it.
  Chris
William Moreno
----------- Mensaje Original --------------
De: Sean Geoghegan [sean@anonymised.com]
Para: Chris Holmes [cholmes@anonymised.com]
Cc: geoserver-devel@lists.sourceforge.net
[geoserver-devel@lists.sourceforge.net]
Asunto: Re: [Geoserver-devel] Initial WMS support in CVS.
Fecha: 06/10/2003 19:38:26
Mensaje:
          Hi Chris,
I was just wondering if there is, or you have thought of a roadmap for
the WMS server once the integration is complete? Personally, I would
love to see the WMS as standards compliant as Geoserver's WFS. I could
probably arrange to have some effort of my own put to this task aswell,
since there are some WMS Features that I would like to use but aren't
present in many other open source offerings.
So maybe a list of features requests and improvements should be put
together??
Sean
Chris Holmes wrote:
>Just wanted to give everyone a heads up that my initial stab at integrated
>WMS support is now in CVS.
>I was trying today to get it working with postgis, but am as of yet
>unsuccessful. I need to deal with bounding boxes, as postgis datasources
>don't like giving them, and the WMS code really likes having them. I'll
>probably implement getBounds for postgis _and_ figure out a way to have
>wms code deal with not being able to query the bounds. Either would fix
>the problem but both cases seem good to solve.
>As for running the wms, the relevant configuration files are either
>integrated with geoserver or in misc/wms. For the layers that you want
>the wms to serve, just fill out the misc/data/FeatureTypes as you always
>do, but add tags for styles:
><Style id="green" filename="green.sld"/>
>The style filenames should be contained in misc/wms/styles/. Note that if
>you have styles from gt2wms you no longer have the styles/ prefix,
>geoserver puts them in a slightly different location (data/styles), and
>resolves the rest of the location for you.
>The layers.xml file is no longer used, so if you have existing installs of
>gt2wms you'll have to change them over to info.xml files. The datasource
>params should stay pretty much the same. The easiest way to move things
>over is to put the related map file from the old gt2wms maps directory
>into the same folder as info.xml, and use the filename parameter to
>specify the name of the file, and it will be resolved into the appropriate
>url parameter. If you must keep it in another location then specify the
>full file url, file:/home/chris/maps/trees.shp.
>I'll try to get a sample file that works for both into cvs pretty soon.
>The one I've been using is a bit large though, so I'm reluctant to put it
>in. If anyone has a nice small shapefile that actually represents
>something real and can make a little map with the wms send it to me and
>I'll add it. The current shapefile is just 4 made up features.
>The capabilities documents are still forked, hopefully we can get some
>good integration on those, since so many of the elements overlap. For now
>the capabilities.xml of gt2wms is just kept in misc/wms, and copied
>directly over.
>As for quering it, I've replaced the /servlet/gt2wms? prefix with
>/geoserver/wms?, to mirror the dispatcher's location of /geoserver/wfs?
>So you can ask wms?request=GetCapabilities and
>wfs?request=GetCapabilities, and get the respective documents (though
>they're still forked, so not super useful yet. Or you can do
>wms?request=GetMap&layer=states and
>wfs?request=GetFeature&typename=states. I think that's all the
>information you need to get started, let me know if there are more
>questions.
>As far as implementation goes, there are definitely integration
>improvements to be made, I've pretty much just hacked together the current
>working solution, TypeInfo (the current geoserver featureType
>representation) objects can turn themselves into LayerEntries, and those
>get added to the WMS. And the capabilities and error reporting are still
>forked. So there are certainly improvements to be made on that front, but
>I think we're on a good start.
>If anyone is interested in this stuff and can handle cvs access I'd love
>feedback, on getting it working and how you might want the configuration
>set up. Information on cvs access is available at
>http://sf.net/cvs/?group_id=25086. We'll go for an early and often
>release relatively soon as well, so that users can spot the new bugs :).
> thanks,
> Chris
>This sf.net email is sponsored by:ThinkGeek
>Welcome to geek heaven.
>http://thinkgeek.com/sf
>_______________________________________________
>Geoserver-devel mailing list
>Geoserver-devel@lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Bladimir Moreno
