I've just recently began looking into this nifty little application, and
am also running into the same javascript message (using IE6 -- I can't
get the SVG plugin to work on my Linux desktop):
'eldnl' is undefined
line: 796, column: 13
Have you had a chance to look into this error? If not, could you
perhaps point me in the right direction so that I could hack around a
bit myself?
Much thanks,
./JRH
Thanks. The "eldnl" error may result from a problem in the php file
generating the "extended layer description", e.g., incorrect handling of
null values. I'll look into this.
Nedjo
Jason,
You might check on the MapBuilder list (cc'd), which is where GeoClient
has moved (as of a week or two ago).
Best Regards,
Rob Hranac
slashdot for geo: http://digitalearth.org
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On
Behalf Of Jason Harley
Sent: Thursday, August 07, 2003 11:14 AM
To: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Re: getting geoclient to work?
application, and
bit myself?
Much thanks,
./JRH
the php file
> Nedjo
This SF.Net email sponsored by: Free pre-built ASP.NET sites including
Data Reports, E-commerce, Portals, and Forums are available now.
Download today and enter to win an XBOX or Visual Studio .NET.
http://aspnet.click-url.com/go/psa00100003ave/direct;at.aspnet
_072303_01/01
Geoserver-devel mailing list
