The query is this.
I miswrote it the other day because I didn't remember the exact form of
it. When I try to execute this query I get the following exception:
java.lang.NullPointerException
at
org.geotools.filter.CartesianDistanceFilter.contains(CartesianDistanceFilter.java:130)
at
org.geotools.data.postgis.PostgisDataSource.getFeatures(PostgisDataSource.java:675)
at
org.geotools.data.AbstractDataSource.getFeatures(AbstractDataSource.java:120)
at
org.vfny.geoserver.responses.FeatureResponse.getQuery(FeatureResponse.java:252)
at
org.vfny.geoserver.responses.FeatureResponse.getXmlResponse(FeatureResponse.java:112)
at
es.pfc.hbarriuso.geoserver.util.WFSServer.getFeature(WFSServer.java:137)
at
es.pfc.hbarriuso.geoserver.GeoserverSoapBindingImpl.getAttributes(GeoserverSoapBindingImpl.java:33)
at
es.pfc.hbarriuso.geoserver.GeoserverSoapBindingImpl.main(GeoserverSoapBindingImpl.java:113)
The classes es.pfc.* belong to my application. I'm trying to envelope
the request and responses of GeoServer within a Web Services framework.
So I don' use the servlets, but I instead use the classes of Geoserver
and Geotools.
I hope this helps to get an answer.
Thanks in advance
---Publicidad--------------------------------------------------------
Juega con Ventura24.es, lotero?=a inteligente y multiplica tus
posibilidades!! http://www.iespana.es/_reloc/email.ventura
try units= instead of unit=
On Sun, 2003-11-02 at 04:19, Hector Hugo Barriuso Mata wrote:
The query is this.
at
at
at
at
at
at
at
at
and Geotools.
Thanks in advance
Juega con Ventura24.es, lotera inteligente y multiplica tus
This SF.net email is sponsored by: SF.net Giveback Program.
Does SourceForge.net help you be more productive? Does it
help you create better code? SHARE THE LOVE, and help us help
YOU! Click Here: http://sourceforge.net/donate/
Geoserver-devel mailing list
I have tried units and it's not the problem. It's indifferent unit or
units, it works whatever the word is.
The problem is in the line <PropertyName>codigopost</PropertyName>,
because if I remove it I get all the features in a radius of 100 meters
from the point of reference.
Any help?
> <GetFeature xmlns:gml="http://www.opengis.net/gml">
> <Query typeName="ejes">
> <Filter xmlns:gml="http://www.opengis.net/gml">
> <DWithin>
> <PropertyName>the_geom</PropertyName>
> <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#32118">
> <gml:coordinates>443454.0,4478531.0</gml:coordinates>
> </gml:Point>
> <Distance
> unit="http://www.uomdict.com/uom.html#meters">100</Distance>
> </DWithin>
> </Filter>
> </Query>
> </GetFeature>
> The query is this.
> at
> at
> at
> at
> at
> at
> at
> at
> and Geotools.
> Thanks in advance
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
nete a los miles de sin pareja en Meetic... te vas a enamorar!
http://www.iespana.es/_reloc/email.meetic
�nete a los miles de sin pareja en Meetic... �te vas a enamorar!
I have resolved my error.
When I was querying a set of properties, I didn't ask for the_geom
property of the DWithin filter, so it couldn't resolve if the feature
was or not inside the distance I specified.
Maybe this helps other people.
Now the query is:
<DWithin>
</gml:Point>
<Distance
units="http://www.uomdict.com/uom.html#meters">100</Distance>
</DWithin>
</Filter>
</Query>
</GetFeature>
> <DWithin>
> </gml:Point>
> <Distance
> </DWithin>
> </Filter>
> </Query>
> </GetFeature>
> The query is this.
> at
> at
> at
> at
> at
> at
> at
> at
> and Geotools.
> Thanks in advance
Sorry about that. I wasn't on email this weekend to respond, I'm glad you
figured it out without too much grief. It's actually come up on the
mailing list before, but we should put it in a more obvious place. I'm
pretty sure the problem should be fixed in the next release, as Jody
Garnett was dealing with that issue on our latest geotools changes to roll
into geoserver.
Chris
Now the query is:
<DWithin>
</gml:Point>
<Distance
</DWithin>
</Filter>
</Query>
</GetFeature>
> > <DWithin>
> > </gml:Point>
> > <Distance
> > </DWithin>
> > </Filter>
> > </Query>
> > </GetFeature>
> > The query is this.
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > and Geotools.
> > Thanks in advance
> > _______________________________________________
Únete a los miles de sin pareja en Meetic... ¡te vas a enamorar!
Chris,
Note that it will no longer be necessary to request the geometry when
using PostGIS with GEOS.
Doug
into geoserver.
Chris
> Now the query is:
> <DWithin>
> </gml:Point>
> <Distance
> </DWithin>
> </Filter>
> </Query>
> </GetFeature>
> > > <DWithin>
> > > </gml:Point>
> > > <Distance
> > > </DWithin>
> > > </Filter>
> > > </Query>
> > > </GetFeature>
> > > The query is this.
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > and Geotools.
> > > Thanks in advance
