[Geoserver-devel] RE: [Mapbuilder-devel] Caps document to configure?
Attached is a screen grab of what this looks like. You can see the
topp:states (upper-left), cite:* (in the middle around 0,0) and tasmania
(lower-right), zooming in on these areas shows more detail. The map extent
is automatically set from the capabilities document.
I implemented it as a new struts tile-def so it could also go in any of the
pages. Perhaps the struts experts can tell me if I missed anything, here is
what I did:
- added a file WEB-INF/pages/mapDisplay.jsp
- added this to the sidebar definition for .mainLayout in
WEB-INF/tile-defs.xml
- modify mainLayout.jsp to: include the mapbuilder.js file, set the
mapbuilder config file and call the body onload function
- added a config file for this at data/mbdemos/geoserverSimple.xml
This will also need an update of the mabuilder lib. Are you planning to
keep the mapbuilder lib as part of the geoserver dist? It can also be a
separate war file but then there would be a dependency. This will affect
how URLs to the library and config file are coded.
Mike
-----Original Message-----
Sent: May 21, 2005 5:52 PM
To: Adair, Mike
Cc: 'geoserver-devel@lists.sourceforge.net'; 'Shorter,
Cameron'; mapbuilder-devel@lists.sourceforge.net; David Blasby
Subject: RE: [Mapbuilder-devel] Caps document to configure?
Awesome, this will be great.
I would definitely like a full page with a bigger map and
editing options. Indeed I think it should probably replace
our current 'demo'
page, and move that one to demo requests or something.
Indeed it's almost tempting to have the full map page on the
'welcome' page instead of our reportings of the capability
document urls. As soon as a user fires up GeoServer she can
start browsing the sample maps.
Also would be cool when your catalog widget is done to give
people a demo they can play with by searching for and adding
other wms/wfs servers to their layers.
But yes, I'm very excited about this. Looks like it'll miss
beta4, but will be a nice new feature for rc1.
Chris
Quoting "Adair, Mike" <Mike.Adair@anonymised.com>:
> Hi,
> I've got a mapbuilder configuration which will read in a WMS caps
> document and convert that to a context to show as a map.
> I've never worked with struts before, but I think I've
managed to hack
> in a little map in the Geoserver sidebar that updates
automatically as
> you add/delete/modify data in geoserver config. I tried deleting a
> data store, and then adding it back, and the map changed
automatically
> at every step. I would attach a screen grab but the
security settings
> on my mail client are preventing that.
> We could probably also put together a full page to edit the
resulting
> context doc (turn layers on/off/delete, reorder layers, etc.)
> Let me know if this would be useful and I can provide the changes,
> (probably not until Monday though).
> Mike
(attachments)
It looks great, Mike.
I think is would be time of providing a bunch of featuretypes that relates each other?
I mean, get rid of the current ones and take some shapefiles, may be from DCW, so a new user gets something nice to test once installed.
what I did:
Mike
From: Chris Holmes [mailto:cholmes@anonymised.com] Sent: May 21, 2005 5:52 PM
To: Adair, Mike
Cc: 'geoserver-devel@lists.sourceforge.net'; 'Shorter, Cameron'; mapbuilder-devel@lists.sourceforge.net; David Blasby
I would definitely like a full page with a bigger map and editing options. Indeed I think it should probably replace our current 'demo'
page, and move that one to demo requests or something. Indeed it's almost tempting to have the full map page on the 'welcome' page instead of our reportings of the capability document urls. As soon as a user fires up GeoServer she can start browsing the sample maps.
Also would be cool when your catalog widget is done to give people a demo they can play with by searching for and adding other wms/wfs servers to their layers.
But yes, I'm very excited about this. Looks like it'll miss beta4, but will be a nice new feature for rc1.
Chris
I've got a mapbuilder configuration which will read in a WMS caps document and convert that to a context to show as a map.
managed to hack
automatically as
you add/delete/modify data in geoserver config. I tried deleting a data store, and then adding it back, and the map changed
automatically
security settings
resulting
Let me know if this would be useful and I can provide the changes, (probably not until Monday though).
Mike
Yes, that sounds reasonable. What are your criteria for a shapefile?
(I'd like to see a point, line, and polygon layers which are all in the same projection and not too big. (Hence the creation of the Tasmania shapefile).
If mapbuilder is to be demonstrated as part of geoserver I think that it needs to be bundled in the geoserver installation.
Note that unless someone has fixed something in the last release, the WMS part of geoserver requires JAI to be installed. (This means that mapbuilder won't work without JAI).
In order to minimise maintainance, I'd like to see geoserver use mapbuider with minimal modifications.
Cameron Shorter
http://cameron.shorter.net
