[Geoserver-devel] RE: missing points (labeling)
Jessie,
I tracked this problem down to the labeler not rendering the same label
text multiple time. This is sometimes a good thing, but (as in this
case) sometimes not.
We talked about making this an option. Is there a way of turning this
off? If so, whats the mechanism?
dave
Quoting Paul Lamb <paul@anonymised.com>:
I've attached the output from 1.24 and 1.30. The numbers that are
missing are from the olr_section.sld and the red sun-burst textmarks
are from the olr_well.sld.
The labeling is really weird, but no matter what map extents I use I
only get at most 30 labels and they aren't always in adjoining
features like the sample.
The textmarks are very consistant. Only one per map.
From: dblasby@anonymised.com [mailto:dblasby@anonymised.com]
Sent: Mon 4/25/2005 8:40 PM
To: Paul Lamb
Subject: missing points
The labeling system has changed quite a bit in geotools. The labels
should no longer overlap. The points should all display, though.
>I will spend sometime on it tonight and see if I can narrow anything
down, to a reproducible test case.
This really helps to track down a fix bugs!! Thanks.
dave
This mail sent through IMP: https://webmail.limegroup.com/
(attachments)
olr_section.sld (3.39 KB)
On Thu, 2005-05-05 at 18:48 -0400, dblasby@anonymised.com wrote:
Jessie,
dave
Right now it is part of the label cache object. Its not optional at the
moment. In geotools it is a simple matter to make it optional. In udig
it is more difficult.
Jesse
> To: Paul Lamb
> dave
User-friendly Desktop Internet GIS (uDig)
http://udig.refractions.net
http://lists.refractions.net/mailman/listinfo/udig-devel
