[Geoserver-devel] Ready to work on geoserver project
I’m ready to work as a developer on the geoserver project. I submitted a contributor agreement (individual_contributor.txt), forked the repository, and built the core and extensions on my local system.
Can somebody suggest a JIRA entry that I should start with?
I should probably start on one of the community modules.
JIRA shows this:
https://osgeo-org.atlassian.net/browse/GEOS-7166?jql=project%20%3D%20GEOS%20AND%20status%20%3D%20Open%20AND%20component%20%3D%20%22Community%20modules%22%20ORDER%20BY%20priority%20DESC
Thanks.
Rod
On Thu, Oct 29, 2015 at 5:10 PM, Rod King (Senior Software Engineer) <
rod.engineer@anonymised.com> wrote:
I'm ready to work as a developer on the geoserver project. I submitted a
Hi Rod,
welcome to GeoServer
The code base is massive, and requires a good knowledge of GeoTools first
(anything that can be shared
to a larger user base is pushed down to GeoTools, the result is, you cannot
do pretty much anything
if you don't have a good grip on Geotools first).
Of course, also good knoledge of the OGC protocols details is required,
since most of what we do
is in that realm.
So, I would also consider tickets in the GeoTools project as a suitable
starting point.
Hum... I would not focus entirely on community modules, as they might not
have a maintainer, which means,
nobody will be there to review your pull request (without a review, it
won't get merged).
I've been going though the recent GeoTools or GeoServer tickets for a but
now, there are not many tickets
that would be suitable for someone new to the gt/gs codebases... maybe this
one?
https://osgeo-org.atlassian.net/browse/GEOT-5222
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
