it seems the change landed after this pull request broke both the build and the
CITE tests:
https://github.com/geoserver/geoserver/pull/44
Build wise we have app-schema breaking with this error:
25-ott-2012 10.22.52 org.geoserver.test.WmsGetFeatureInfoTest
testGetFeatureInfoGML
INFO: WMS =GetFeatureInfo GML response:
<ServiceExceptionReport version="1.3.0"
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost:8080/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException>
java.lang.IllegalStateException: Cannot guess file extension for
invalid MIME type: 'geoserver-GetFeatureInfo'
Cannot guess file extension for invalid MIME type: 'geoserver-GetFeatureInfo'
</ServiceException>
</ServiceExceptionReport>
The CITE tests are also breaking on a mime type check, I don't have
proof that the commit
is what breaking them, but it would seem likely
Can we get a quick fix, or shall we revert the change?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hmmm… I guess we should roll this back for now and revisit why the cite tests are breaking. Who wants to do that?
On Thu, Oct 25, 2012 at 3:27 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
CITE tests:
invalid MIME type: ‘geoserver-GetFeatureInfo’
Cannot guess file extension for invalid MIME type: ‘geoserver-GetFeatureInfo’
The CITE tests are also breaking on a mime type check, I don’t have
Ing. Andrea Aime
@geowolf
Technical Lead
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Ok, trying to reproduce the issue on the CITE test server failed after a couple of tries, so I went ahead and reverted the changes to get the build green again. Locally, I was able to reproduce the problem in the application-schema tests so I investigated a bit more there.
After correcting the error message, I see this:
Cannot guess file extension for invalid MIME type: ‘application/vnd.ogc.gml/3.1.1’
According to my reading of http://portal.opengeospatial.org/files/?artifact_id=37743 the MIME type for GML3.1.1 should actually be “application/gml+xml; version=3.1.1” . Am I misunderstanding something? I don’t think it’s valid to have a slash in the type or subtype based on my reading of http://tools.ietf.org/html/rfc2045 .
David Winslow
OpenGeo - http://opengeo.org/
On Thu, Oct 25, 2012 at 10:13 AM, David Winslow <dwinslow@anonymised.com> wrote:
I’m happy to revert, but (of course) there’s a bug in the custom exception message I added - it is showing the partially constructed filename rather than the invalid MIME type string. It would probably be useful in tracking down the problem to rerun with the error string corrected.
David Winslow
On Thu, Oct 25, 2012 at 10:09 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
CITE tests:
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
