[Geoserver-devel] Recent GeoServer releases gone from Sourceforge
am I missing anything or are any GeoServer versions 2.20 onwards gone from the Sourceforge download page?
https://sourceforge.net/projects/geoserver/files/GeoServer/
Most recent I can find there is 2.19.2 since a couple of hours. :thinking:
Is this an issue with Sourceforge or were the releases removed?
Apologies if this has already been posted elsewhere.
Many thanks,
Matthias
Hi there,
wow, yes, I can confirm that’s the case. The project home page is still reporting the latest release,
but when following the links, puff, files gone. The “Files” tab indeed shows only 2.19.2 and earlier.
Looks like several other projects are affected too, here are some random recently opened tickets:
https://sourceforge.net/p/forge/site-support/24228/
https://sourceforge.net/p/forge/site-support/24229/
https://sourceforge.net/p/forge/site-support/24230/
You can find plenty at: https://sourceforge.net/projects/forge/
Let’s see, I guess SF is either going to fix it, or we’ll soon get an unfortunate communication from them…
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Seems it’s back :tada:
And I have a new motivation to make our build pipeline independent of this :wink:
Have a good one,
Matthias
(attachments)
On 1/19/23 15:27, Andrea Aime wrote:
Hi there,
On Thu, Jan 19, 2023 at 3:07 PM Matthias Loeks <matthias@anonymised.com> wrote:
Many thanks,
Matthias
Geoserver-devel mailing list
Andrea Aime
== GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions Group phone: +39 0584 962313
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail
Can we recover from build server at all?
(attachments)
Jody Garnett
