I am planning to add an optional HTTPS filter for the authentication filter chains. If this filter is active, an incoming HTTP request should be redirected to an HTTPS request.
Example:
http://my.geoserver.org/goeserver?service=wms&request=getCapabilites
is redirected to
https://my.geoserver.org/goeserver?service=wms&request=getCapabilites
I am unsure how to deal with a reverse proxy.
The client sends to the proxy
The proxy forwards
http://my.geoserver.local/goeserver?service=wms&request=getCapabilites
Geoserver sends a redirect
https://my.geoserver.local/goeserver?service=wms&request=getCapabilites
This URL is useless for the client. I know proxies which can handle redirects, the proxy sends back a redirect with
Should we rely on this fact ?. Or is it better to give the optional possibility to configure the external geoserver url up to the context root ( https://**my.geoserver.org/**goeserver) and the filter calculates the full external URL itself.
Thanks
On Mon, Jan 14, 2013 at 10:46 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
We already have the configuration of the external URL, it’s called “Proxy base URL”.
Every URL generated by GeoServer for client consumption must be processed
via URLManglers, which happens when calling:
ResponseUtils.buildURL(String baseURL, String path, Map<String, String> kvp, URLType type)
Failure to call the above method when creating a URL that a client will get back
from GeoServer is a bug
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Jan 14, 2013 at 10:54 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Forgot to add, one of the URL manglers is responsible for applying the “proxy base url”
Ing. Andrea Aime
@geowolf
Technical Lead
Nice, a singleton filter object should be sufficient and activation is done by a check box.
Thanks
2013/1/14 Andrea Aime <andrea.aime@anonymised.com>
On Mon, Jan 14, 2013 at 10:46 AM, Christian Mueller <mcrmcr21@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
