Hi Mauro & all,
I noticed that if multiple layers in a layergroup GetLegendGraphic use the same default style, that style is rendered redundantly for each layer instead of only once. In our case, this is a layergroup that contains multiple bathymetry tifs using the same style.
It seems like each unique style/rule combination should only be rendered once. In this case each style would potentially have multiple layer titles, maybe sorted and stacked vertically above the legend. Also, there are several places in the code where the layer is evaluated when making rendering decisions. For these decisions, would it be sufficient to just use the first layer in the set using that style/rule combination?
If those few issues can be decided, it seems fairly straightforward to implement this. Mauro, any thoughts? Are you interested in making these tweaks, or would you rather I took a stab at it?
Shane
Shane StClair
Software Engineer
Axiom Consulting & Design
http://www.axiomalaska.com
Oh, and one other issue with redundant styles in layergroup GetLegendGraphic: when a style is rendered redundantly, the name of the last layer gets used in all of the renderings.
Best,
Shane
On Fri, Apr 12, 2013 at 1:49 AM, Shane StClair <shane@anonymised.com.2677…> wrote:
Hi Mauro & all,
Shane
Shane StClair
Software Engineer
Shane StClair
Software Engineer
2013/4/12 Shane StClair <shane@anonymised.com>
Hi Mauro & all,
once.
I don't know if this is the correct behaviour. In my opinion the legend
should list each layer with its style, also if they are identical, by
default. Maybe we cound add a legend option (something like
groupByStyle=true) to introduce the behaviour you describe on demand. Any
other opinions?
I don't know if I can find time to implement that, but if you can submit a
patch, I can make a review.
Thanks.
Mauro
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
This could be a bug.
Could you open a jira issue for that with enough info to reproduce it?
Thanks
Mauro
2013/4/12 Shane StClair <shane@anonymised.com.2677…>
Best,
Shane
@mauro_bart
On Fri, Apr 12, 2013 at 1:49 AM, Shane StClair <shane@anonymised.com> wrote:
Hi Mauro & all,
Shane
Shane StClair
Software Engineer
Shane StClair
Software Engineer
