Dear Sir,
I want to customize a Web Processing Service, Do i need to run geoserver through Eclipse IDE or is it fine if i run it as a java application? and im using geoserver with tomcat without the embedded jetty, which is creating a startup problem in eclipse. Is it compulsory that i should go with jetty? I would be greateful if you let me know. And I had registered the process factory but it doesnt work. Can i guide me clearly step-by-step. the guide seems little generalised. do i need to have geoserver src directory to be imported on eclipse to do all these. I have even tried with the geotools guide, but that doesnt work either. Iam stuck up with ProcessFactory. I would be obliged with your responbse.
Thank You
GK
