[Geoserver-devel] REGARDING DEPLOYMENT OF A JAR FILE WITHIN GEOSERVER AS A PROCESS
Hie everyone,
I have just started Geoserver. I have an open source jar file, i want to customise a process class and include this jar file within and then get this registered with Geoserver. Is this posssible. I have started geoserver throughj eclipse, and abruptly tomcat stops running, after changing the server settings to jetty (initially i was using tomcat as a standalone server), but now, for eclipse integration i dont find any guide other than jetty., so i had no option rather than giving jetty port no.
Now, when i run tomcat normally, itz fine, but when running with geoserver, it give outofmemory exception, application or context required. Any guidance for further precedence would be greatly obliged. Please do the needful
Hi
First we need to know your platform. Second, did you try to start the JAVA VM with an -Xmx command line argument ?
Christian
On Fri, Jul 18, 2014 at 6:58 AM, Girija Kalyani <smileismystyl@anonymised.com> wrote:
Hie everyone,
Want fast and easy access to all the code in your enterprise? Index and
search up to 200,000 lines of code with a free copy of Black Duck
Code Sight - the same software that powers the world’s largest code
search on Ohloh, the Black Duck Open Hub! Try it now.
http://p.sf.net/sfu/bds
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
