[Geoserver-devel] Register new WPS ProcessFactory
I’m trying to register a new ProcessFactory in order to generate a new namespace for custom WPS proessess.
I’ve dug into wps-core and looked at the applicationContext.xml
From that i’ve found that I should create a new marker interface for my processes to inherit from them register a newly parametrized instance of org.geoserver.wps.jts.SpringBeanProcessFactory in my jar’s applicationContext.xml below.
The process is defined as such:
package …
import …
@DescribeProcess(
title = “UGC to Feature Converter”,
description = “Converts a NOAA UGC code to corresponding features”,
version = “1.0”)
public class UGCFeatureProcess implements NWSProcess { … }
But after all this I can’t get the processes to register with the new namespace. I have to revert the inheritance to GeoServerProcess…
Should this work? I saw earlier in the wps-core application context some depends-on flags for WPSInfo relating to other bean factories. Is my factory being instaniated too late to be captured?
Thanks much,
Tom.
On Tue, Jun 3, 2014 at 10:33 AM, Tom Kunicki <tom.kunicki@anonymised.com>
wrote:
I'm trying to register a new ProcessFactory in order to generate a new
I've dug into wps-core and looked at the applicationContext.xml
From that i've found that I should create a new marker interface for my
in my jar's applicationContext.xml below.
<beans xmlns="http://www.springframework.org/schema/beans&quot;
        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
        xsi:schemaLocation="http://www.springframework.org/schema/beans
    http://www.springframework.org/schema/beans/spring-beans-2.5.xsd&quot;&gt;
    <bean id="nwsProcessFactory"
class="org.geoserver.wps.jts.SpringBeanProcessFactory">
        <constructor-arg index="0" value="NWS specific processes"/>
        <constructor-arg index="1" value="nws"/>
        <constructor-arg index="2"
value="com.twc.geoserver.wps.NWSProcess"/>
    </bean>
    <bean id="ugcFeatureProcess"
class="com.twc.geoserver.wps.UGCFeatureProcess">
        <constructor-arg ref="catalog"/>
    </bean>
</beans>
package ...
import ...
@DescribeProcess(
    title = "UGC to Feature Converter",
    description = "Converts a NOAA UGC code to corresponding features",
    version = "1.0")
public class UGCFeatureProcess implements NWSProcess { ... }
But after all this I can't get the processes to register with the new
namespace. I have to revert the inheritance to GeoServerProcess...
That's not the issue, the factory ends up being registere in SPI, which
uses the class names as
the discriminant, so it's not possible to have two SpringBeanProcessFactory
around.
Long story short, you have to subclass SpringBeanProcessFactory and create
also your own
factory for it to work
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
Thanks, that did the trick.
Tom
On Tue, Jun 3, 2014 at 4:04 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Jun 3, 2014 at 10:33 AM, Tom Kunicki <tom.kunicki@anonymised.com> wrote:
package …
import …
@DescribeProcess(
version = “1.0”)
That’s not the issue, the factory ends up being registere in SPI, which uses the class names as
the discriminant, so it’s not possible to have two SpringBeanProcessFactory around.
Long story short, you have to subclass SpringBeanProcessFactory and create also your own
Ing. Andrea Aime
@geowolf
Technical Lead
