On Fri, Sep 18, 2015 at 12:53 AM, Kevin Smith <smithkm@anonymised.com> wrote:
I have the test failing without the patch although the way I
accomplished it isn't pretty.
Wicket ain't pretty....
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
