as you are probably aware the GeoServer GUI allows people to write custom store configuration panels and plug them in by declaring a DataStorePanelInfo bean in the spring context.
The current lookup logic searches for a match of the store factory/store format, which is fine in general, but a bit annoying for a case that I’m handling.
I’m trying to add the file browser for the GDAL based coverage stores, which are plenty and whose list is growing with time.
Given they all share the same base Format class, I would like to change the matching logic so that a single DataStorePanelInfo referring to that base class
works for all the GDAL formats.
The logic in StoreExtensionPoints would be changed so that exact matches are returned right away, and matches by superclass (using Class.isAssignableFrom) are allowed as fallbacks, eventually sorting them to pick the closest match (same code as the one available in Dispatcher.response, just working on different object types).
What do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Works for me, no objection.
On Thu, Jun 13, 2013 at 3:33 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
What do you think?
Ing. Andrea Aime
@geowolf
Technical Lead
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
