In the context of NSG community module I have the necessity to override the default WFS 2.0 XML reader [1] to
handle an extra parameter and perform some extra logic when parsing a GetFeature XML POST request.
Currently the disptacher will throw an exception if more than one XML reader bean exists for the same service,
version and operation [2]. I would like to relax that behavior relying on beans extension priority [3] to select
between two XML readers that support the same service, version and operation.
This will allow plugins to use GeoServer standard extension mechanism to override the default XML parsing for a
certain service request. This change will be completely backwards compatible and I don't see any negative impact.
Any objections ?
Nuno Oliveira
[1] https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/xml/v2_0/WfsXmlReader.java
[2] https://github.com/geoserver/geoserver/blob/master/src/ows/src/main/java/org/geoserver/ows/Dispatcher.java#L1279-L1295
[3] https://github.com/geoserver/geoserver/blob/master/src/platform/src/main/java/org/geoserver/platform/ExtensionPriority.java
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
