[Geoserver-devel] Release GeoTools 12.0 / GeoServer 2.6.0 plan
Provided no one objects I’ll kick off these releases either late tonight (GMT) or first thing tomorrow (Tuesday) - If you have anything you would like to go in to the release please commit today.
Ian
Ian Turton
Ian several fixes (to CSS Edit page and documentation) have been merged on to master, and now need to be back ported to 2.6.x before the release. Sorry I do not have time to help.
Jody Garnett
Ian
Ian Turton
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.coms.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Hi Jody,
it seems to me Justin also backported the CSS fixes:
https://github.com/geoserver/geoserver/commits/2.6.x
So… we should be good to go release wise, unless I’m missing something
On Mon, Sep 22, 2014 at 6:39 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Jody Garnett
Ian
Ian Turton
GeoTools-Devel@lists.sourceforge.net
Cool then I’ll start the release train this afternoon, with luck I can get GeoTools done in time for Kevin to do a GCW release on it and do GeoServer tomorrow.
Ian
On 23 September 2014 13:48, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
The GeoTools 12.0 release artefacts are available to test/build against on http://ares.boundlessgeo.com/geotools/release/12.0/
Everyone if you could kick them around a bit and make sure everything looks good I’d be grateful.
Kevin if you could let me know when you’ve released GWC I’ll kick off the GeoServer 2.6.0 release.
Ian
Ian
Ian Turton
Hi Jody,
Ian Turton
On Mon, Sep 22, 2014 at 6:39 PM, Jody Garnett <jody.garnett@anonymised.com403…> wrote:
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
That is great - thanks Justin.
It is still worth double checking master vs 2.6.x if we get a chance today.
Jody Garnett
On Tue, Sep 23, 2014 at 5:48 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Sorry, I’ll try to fit it in, but my bandwidth for this is constrained at the moment.
Ian
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
http://boundlessgeo.com/
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
looks good I'd be grateful.
Tried a build from clean repo, worked:
[INFO]
[INFO] BUILD SUCCESS
[INFO]
[INFO] Total time: 41:36.355s
[INFO] Finished at: Tue Sep 23 18:21:30 CEST 2014
[INFO] Final Memory: 99M/144M
[INFO]
mvn --version
Apache Maven 3.0.4 (r1232337; 2012-01-17 09:44:56+0100)
Maven home: /home/aaime/apps/apache-maven-3.0.4
Java version: 1.7.0_67, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-7-oracle/jre
Default locale: it_IT, platform encoding: UTF-8
OS name: "linux", version: "3.8.0-44-generic", arch: "amd64", family: "unix"
Ing. Andrea Aime
@geowolf
Technical Lead
OK shall I just release GeoServer with the current release of GWC (1.5.3) from July ? or the 1.6-RC?
Ian
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Hey Ian. One issue Kevin ran into was the geotools artifacts not being available in the maven repo. Have you run the geotools publish step yet?
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
On 23 September 2014 13:48, Andrea Aime andrea.aime@anonymised.com wrote:
Hi Jody,
Ian Turton
On Mon, Sep 22, 2014 at 6:39 PM, Jody Garnett jody.garnett@anonymised.com wrote:
Jody
GeoTools-Devel@anonymised.comt
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Whoops - I knew there was something I had to do this morning
I’ll do it now
Ian
On 24 September 2014 14:39, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Wednesday, September 24, 2014, Ian Turton <ijturton@anonymised.com> wrote:
Ian
Justin Deoliveira
VP Engineering | Boundless
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Thanks, Ian.
Releasing with 1.5.3 probably wouldn’t work. There are changes in the 1.6 branch that that GS 2.6 depends on so it would just break things. As a last resort, 1.6.0-RC1 would be a better choice.
My time Is still constrained but I think I should be able to complete the process today.
I’ll do it now
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Wednesday, September 24, 2014, Ian Turton <ijturton@anonymised.com…> wrote:
Ian
Justin Deoliveira
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Thanks Kevin
Is this mosaic issue that has come up a blocker for 2.6.0? from the sound of it is serious but does it only affect Finland? :slight_smile:
Ian
On 24 September 2014 16:52, Kevin Smith <ksmith@anonymised.com> wrote:
Thanks, Ian.
Ian Turton
I’ll do it now
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Justin Deoliveira
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
Ian, at some point we have to make a cut, otherwise we are going back to a feature based release model, instead of a time boxed one.
Or alternatively, we may decide to jump over this one shift all our programmed releases one month?
But honestly I don’t like the idea one bit.
On Wed, Sep 24, 2014 at 6:38 PM, Ian Turton <ijturton@anonymised.com…> wrote:
Thanks Kevin
Ian
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, Ian.
Ian Turton
I’ll do it now
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
On 24 September 2014 14:39, Justin Deoliveira <jdeolive@anonymised.com.3839…> wrote:
Ian
Justin Deoliveira
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
I don’t seem to have permissions to deploy to the new maven repository. Otherwise everything is built, tested, and ready to go. I’ll ask Justin about it when I see him tomorrow morning.
Kevin Smith
+1-778-785-7459
@boundlessgeo
Thanks Kevin
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, Ian.
Ian Turton
I’ll do it now
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Justin Deoliveira
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
GWC 1.6.0 is in the maven repo.
I’ll handle the rest of the release process as time permits but it shouldn’t be holding up GeoServer any more.
Kevin Smith
+1-778-785-7459
@boundlessgeo
Kevin Smith
+1-778-785-7459
@boundlessgeo
On Wed, Sep 24, 2014 at 6:38 PM, Ian Turton <ijturton@anonymised.com> wrote:
Thanks Kevin
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, Ian.
Ian Turton
I’ll do it now
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Justin Deoliveira
@boundlessgeo
Ian Turton
Ian Turton
Ian
Kevin Smith
+1-778-785-7459
@boundlessgeo
Ian
Ian Turton
Hi Jody,
Ian Turton
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ian
Ian Turton
