There Release Guide has been updated please review and let me know..
http://docs.codehaus.org/display/GEOSDEV/7+Release+Guide
Kind Regards
Clint Lewis
Kind Regards
Clint Lewis
I made a release but Jetty didn’t come along in the geoserver-bin.zip file is there something special I have to do to make it magically appear?
Jesse
n 31-May-06, at 3:10 AM, Clint Lewis wrote:
There Release Guide has been updated please review and let me know…
Kind Regards
Clint Lewis
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrceforge.net
just so you know. I’m on the 1.4.x branch and just ran mvn clean assembly:assembly. I got the 4 zip files but when I unzipped the -bin.zip file I just had bin, etc, logs, webapps, license.txt and start.jar. When I run start.sh or start.jar I get the following exception:
java.lang.ClassNotFoundException: org.mortbay.xml.XmlConfiguration
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at org.mortbay.start.Main.invokeMain(Main.java:167)
at org.mortbay.start.Main.start(Main.java:508)
at org.mortbay.start.Main.main(Main.java:116)
Jesse
Jesse
Kind Regards
Clint Lewis
Geoserver-devel@anonymised.come.net
You will need to run mvn org.codehaus.mojo:dependency-maven-plugin:copy-dependencies to download the appropiate jars namely Jetty. I have updated the Release Guide to explain this.
Thanks
Jesse Eichar wrote:
I made a release but Jetty didn't come along in the geoserver-bin.zip file is there something special I have to do to make it magically appear?
Jesse
Kind Regards
Clint Lewis_______________________________________________
Geoserver-devel@lists.sourceforge.net <mailto:Geoserver-devel@lists.sourceforge.net>
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM MSN : louiecw@anonymised.com
IM Skype: louicw
Sorry I have updated the http://docs.codehaus.org/display/GEOSDEV/2+Deploying to include this instruction.
Thanks
Jesse Eichar wrote:
I made a release but Jetty didn't come along in the geoserver-bin.zip file is there something special I have to do to make it magically appear? Jesse
Kind Regards
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
Hi Jesse,
This is related to your previous mail, please see that mail.
Kind Regards
Clint Lewis
Jesse Eichar wrote:
just so you know. I'm on the 1.4.x branch and just ran mvn clean assembly:assembly. I got the 4 zip files but when I unzipped the -bin.zip file I just had bin, etc, logs, webapps, license.txt and start.jar. When I run start.sh or start.jar I get the following exception:
at org.mortbay.start.Main.main(Main.java:116)Cheers,
Jesse
Jesse
Kind Regards
https://lists.sourceforge.net/lists/listinfo/geoserver-devel_______________________________________________
https://lists.sourceforge.net/lists/listinfo/geoserver-devel------------------------------------------------------------------------
I would like to remove this requirement and attach the goal to the install phase. Any progress on that front?
Thanks
Jesse
Kind Regards
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
No progress on this, I need to add this still.
Thanks
Kind Regards
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
Ok, it actually is there but the reason its not working is that you need to run the install phase manually.
So the command becomes:
mvn -DconfigId=release clean install assembly:assembly
Is there is a problem in that this will build twice but we can figure out a better solution later.
Note: the -DconfigId things makes sure the resulting release has the correct configuration, ie predefined demos, etc...
I have update the release docs:
http://docs.codehaus.org/display/GEOSDEV/7+Releasing
Thanks
Kind Regards
Justin Deoliveira
