[Geoserver-devel] Release manager needed for 2.17.5 (in 2-ish days)
just checked the release schedule, we are still missing a release manager for the last 2.17.5 release
(scheduled in 2 day, but as we all know, the date can be flexible).
Any takers?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Taken, will be bugging Jody for help though.
Gabriel Roldán
Thanks Gabriel!
Regards, Andrea Aime
Thanks Gabe:
I don’t have a quick way to check what revisions to release (anyone have a trick?) Downloading a nightly build and checking VERSION.txt gives me:
version = 2.17-SNAPSHOT
git revision = 88ba90f64b85980e1310d3fbbe5fa2b47b582997
git branch = origin/2.17.x
build date = 19-Feb-2021 04:41
geotools version = 23-SNAPSHOT
geotools revision = 3329a172a661a65c9d7696292686a67c8d681593
geowebcache version = 1.17-SNAPSHOT
geowebcache revision = 7c25819bee3ae7b045bb922ab19d3ff64a20202e/7c258
hudson build = -1
I will start releasing GeoTools and report back on geotools-devel…
Jody Garnett
Starting a new thread.
By looking at GWC’s 1.17.x changes, it seems there are actually no changes since 1.17.4: https://github.com/GeoWebCache/geowebcache/compare/1.17.4…1.17.x
So question is, do we make a no-op gwc release, or reuse 1.17.4?
On Fri, 19 Feb 2021 at 10:34, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Gabe:
hudson build = -1
Jody Garnett
The GeoTools release build went smoothly, I just verified all the artifacts.
https://build.geoserver.org/view/release/job/geotools-release/
I’ll proceed with publishing it and start the GeoServer release build against GT 23.5 and GWC 1.17.4, since IMHO there’s no point in re-releasing gwc without any changes. Any objections?
Gabriel Roldán
No objection, there are indeed no new commits since 1.17.4
On Fri, 19 Feb 2021 at 16:32, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Feb 19, 2021 at 5:22 PM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
I believe we did the same for 1.16.4 (or so) when there were no commits with no problems
Ian
Release artifacts ready, if someone can give them a shot. I’ll proceed in about an hour with the publishing job
https://build.geoserver.org/view/release/job/geoserver-release/20/artifact/distribution/2.17.5/
Gabriel Roldán
