[Geoserver-devel] release module doesnt build
I get a failure by depending on jetty-util. Andrea you just upgraded the
jetty dependencies, did this one get left out.
Which brings up another point. Based on recent experience in geoserver
and geotools, changes to the build system are being made without testing
the entire build system. It is not enough to test just mvn install.
To build a release in geoserver is just a few commands, and doesn't take
too much time, so I don't think it is an unreasonable request.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
May be... is it out of the build? I usually do a mvn clean install before committing.
What's the problem?
Anyway, I did revert to 6.0.0rc2 so it's not a matter or the version, but maybe jetty-util
was not among the dependencies before.
Okay, fair enough.
This module is not part of the normal build cycle, only used for
releasing. Adding the dependency in fixes the problem.
before committing.
What's the problem?
Okay, fair enough.
!DSPAM:1004,452bcab4136581527717022!
Justin Deoliveira
I see... would it be possible to make cruise control complain about this kind of errors
as well? :slight_smile:
Yeah we should be able to run the release command instead of just
install. I will look into doing this. Good idea :slight_smile:
kind of errors
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
!DSPAM:1004,452bcc03138601425493344!
Justin Deoliveira
