[Geoserver-devel] Release reminder for 2.19.1 ...
A reminder that 2.19.1 goes out next week!
I will be working on it over a couple of days starting on the 18th. Please speak up if you have a fix or PR that needs to be reviewed before this goes out!
Jody Garnett
Small update the release has gotten stuck on the same m2 issue being discussed by Andrea:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-install-plugin:3.0.0-M1:install (default-install) on project gt-brewer: ArtifactInstallerException: Failed to install metadata org.geotools:gt-brewer/maven-metadata.xml: Could not parse metadata /var/lib/jenkins/.m2/repository/org/geotools/gt-brewer/maven-metadata-local.xml: in epilog non whitespace content is not allowed but got T (position: END_TAG seen ...</metadata>\nT... @12:2) -> [Help 1]
I do not know of an easy fix for this and will have a chance to work on this again this afternoon.
Volunteers are welcome to assist (as indicated in the meeting notes I have some availability, but if anyone needs this release promptly they are welcome to help out).
Jody Garnett
Believe I’ve fixed the metadata file. Let me know if it works.
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Excellent, thank you Andrea - build is proceeding now.
By the time you read this the artifacts should be available for review/testing.
Jody
Jody Garnett
