On Wed, Apr 20, 2016 at 3:28 PM, Chris Snider <chris.snider@anonymised.com>
wrote:
I was wondering about the j_spring_security_check endpoint on the pages.
I recalled seeing something from Justin back in March about the endpoint
changing to /login.
“In terms of compability issues the only issue I have found thus far is
the issue with the spring security login endpoints changing (ie.
/j_spring_security_check is now /login).”
Did spring not actually change to login?
I'm not sure, but that was the first actual change that I've tried, making
the home page use "../login" instead of "../j_spring_security_check" and
... it did not work
at all (no login working, not even the main home page, let alone from the
others).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
